04-19-2021, 10:45 AM   #1
Pentax P30 possible battery issue
So I've recently bought a P30 (my first analogue camera), but I can't get it to work.
The film advance lever won't move the full distance. I've got film loaded (not sure if that matters) and the camera came with batteries installed. I could see the icons light up when looking down the viewfinder so wasn't sure if the batteries were the issue but I read somewhere else it could be. I have now tried several sets of brand new batteries but the issue still persists.
The only reason I still think it could be battery related is that after not touching the camera for a couple of days it worked once immediately after turning it on, then back to not working.
Any advice on this would be appreciated!
04-19-2021, 11:05 AM   #2
sergysergy's Avatar
Is film new? Make sure it is installed correctly. If not maybe you have finished it?
04-19-2021, 11:19 AM   #3
QuoteOriginally posted by sergysergy Quote
The film is new and I'm pretty sure it's installed correctly. I found a copy of the manual online and followed that. But as the lever to advance the film won't fully move I can't advance the film at all.
05-14-2021, 12:55 PM   #4
Perhaps the film lever does move the full distance, but it is not cocking the shutter? After you wind on, is it possible to wind on another frame?
I have seen this problem reported before, apparently caused by worn rubbers in the film advance mechanism. See thread here:
The Classic Camera Repair Forum: Pentax P30 wind on problem
batteries, battery, camera, film, issue, p30, p30 possible battery, pentax p30
Pentax P30 light meter issue cajafu Film SLRs and Compact Film Cameras 5 01-25-2021 12:04 PM
Pentax P30 - Possible battery/electronics issue RuairiM95 Troubleshooting and Beginner Help 6 05-11-2020 12:10 AM
Pentax P30 battery Colin Mayer Visitors' Center 11 03-15-2020 01:31 AM
Pentax P30 with Pentax PK-A 50mm 1:1.7 stuck! Rewindfishwalk Troubleshooting and Beginner Help 3 06-29-2019 03:13 PM
p30 & helios 44m metering issue.... echospace Pentax SLR Lens Discussion 6 07-19-2009 03:16 PM
All times are GMT -7. The time now is 12:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
