Originally posted by titrisol Set the ISO to 250 (1 notch over 200) or 320 (2 notches) for Portra
It used to be quite forgiving on the highlights so overexposing is hard.
I would say it's near impossible to overexpose Portra 160/400 . . . specially when you compare it to digi RAW files.
So I established an ideal exposure "0" and increased exposure time 1 stop until I overexposed by 10 stops which I thought would cover the range. Obviously not enough. I then applied some minor post work of white balance and levels to the +10 overexposed scan to get the larger image below +8 to +10 images. The digi RAW files are completely unusable by +5. I've tried this on newer digis and not much has changed.
In practical application, this ultrawide latitude can be used to capture a very wide latitude on one frame.
In this image, I am able to derive useful detail in the deep shadows as well as what would appear to have been blownout highlights. However, you will have to apply post work of shadows and highlights tool in order to achieve this. Exposure can be adjusted in scan itself too to derive even more detail.
The general rule of thumb when using color negatives and b&w film is expose for the shadows because the film will take care of the rest. To be more precise, you properly expose the most critical area and the rest will fall where they may and with Portra you will have a lot of overexposure reach and some underexposure.
Here is the full range I tested . . .
