05-29-2021, 12:31 PM   #1
Pentax Auto 110 Potential Stuck Aperture
I just acquired a Pentax Auto 110 SLR with 2 lenses, auto-wonder, case, and a couple of rolls of film. When I got it, I could not see through the viewfinder, the film advance lever would move about halfway. The aperture diaphragm seems to be shut (or stopped) all the down. There is no light being let through the aperture diaphragm. Therefore I cannot see anything through the viewfinder.
I just bought a pair of brand new Energizer 357/303 1.55v batteries and put an old roll of half-used 110 film that was in the camera.
A solid yellow light shows up in the viewfinder, but nothing happens when I press the shutter button, also, nothing happens when I try to cock the film advance lever. I still cannot see through the viewfinder.
Is this a known problem? How can I fix this really neat camera?
05-29-2021, 01:39 PM   #2
The solid yellow light means the meter is working and there is power...
If I remember right, my Auto 110 did that once... it somehow got itself halfway wound between frames...
I can't look right now because it has film in it, but does it have the little pin that needs to be pushed over by the advancing film for it to cock the shutter properly?
I might be confusing myself with a different 110 camera...
If the mirror is up and you can't see through the lens from the back, that means the shutter is closed (there is no aperture mechanism on the Pentax 110s).
But it's possible the shutter is stuck open and the mirror up - you wouldn't be able to see through the viewfinder, but with no film in it and the back open, you'd be able to see through the lens.
And I guess when you say the aperture mechanism is shut, you're looking at the shutter from the lens side?
-Eric
05-29-2021, 01:40 PM   #3
jlstrawman's Avatar
Last produced 1985.
Maybe some help here:
Pentax 110
05-29-2021, 06:20 PM   #4
Mine did that. Spray electrical contact cleaner into the little plunger switch on the top left of the camera (that is utilized when you attach the flash), and into and around the shutter release button.
No need to take anything apart.
Works perfectly now.
Contact cleaner:
amazon.com: CRC 05103 QD Electronic Cleaner -11 Wt Oz: Sports & Outdoors?tag=pentaxforums-20&
advance, aperture, auto, camera, diaphragm, film, light, pentax, pentax auto, viewfinder
Pentax Q, Q-7 vs. Auto 110 vs. 110 Instamatic size comparison steamloco76 Pentax Mirrorless Cameras 9 04-30-2021 09:49 PM
Pentax auto 110 super slr - film advance lever is stuck need advice teamrums Visitors' Center 4 03-19-2021 09:25 PM
Machinery VROOM, VROOM ! FA 55-110 mm f/5.6 ED @ 110 mm FL and f/11. RICHARD L. Post Your Photos! 3 08-28-2020 03:50 PM
Pentax Auto 110 stuck Sjabruz Troubleshooting and Beginner Help 2 07-01-2015 09:34 PM
Something nice for our Pentax Auto 110 users: Auto 110 lens database Adam Pentax Film SLR Discussion 3 09-24-2010 06:42 AM
All times are GMT -7. The time now is 09:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
