Originally posted by Evertking The border will be in the middle of the next frame... It's hard to describe. I watch the top of the camera as I advance the lever and the knob on top of the camera above the film canister seems like there is slack in the film as it doesn't turn as it should as I'm advancing the lever. Uuugh... That's confusing, gotta be.
It could be that button on the bottom... It's in a bad spot and I could be pushing it.
Seems that your film transport is not working properly.
Try it without film in the camera, open the back and check the following:
- Rewind button is popped out
- Sprocket-hole roller doesn't move freely (especially clockwise)
- When you wind the film, the film roller should rotate 1 full revolution
If the rewind button if pushed you might be able to free it using a bamboo stick to bend it back to the center
