07-11-2021, 09:29 AM   #1
ME Super tool to remove ASA dial nut
I want to remove the top cover from my ME Super, but the nut on the ASA dial is really stuck. I don't have a proper tool which I think is this in the service manual, attached.
I've tried using two flathead small screwdrivers but I can't get it to move, and I'm just damaging it.
Where can I get a tool like this, or how can I get it off?!
07-11-2021, 09:48 AM - 1 Like   #2
grog85361's Avatar
Try looking for a "Camera Spanner Wrench", such as the one pictured here: 5mm Spanner Wrench Tool | USCamera | Downloads Parts Tools MoreUSCamera
I have one I got off ebay similar to this: Adjustable Camera Lens Spanner Wrench 3 Tips Flat Opening Open Repair Tool set | eBay
These are adjustable and have changeable tips to cover many tasks.
Also, is that nut a left hand thread? I think the film advance lever nut is left hand, but I don't know about the ASA dial.
Good luck!
07-11-2021, 09:48 AM   #3
Does the manual say if it's a left or right hand turn?
07-11-2021, 09:53 AM   #4
I found a guide that said it was a "conventional thread", which I assume means right handed.
---------- Post added 07-11-21 at 10:18 AM ----------
That camera wrench looks perfect. The cheaper ones seem to start at 10mm though, will do some digging and see if I can find one that goes smaller. The dial nut holes are around 8mm apart.
07-11-2021, 09:17 PM - 1 Like   #5
Not a Number's Avatar
The cheaper ones may not be worth the money even if they did fit:
Lens Spanners -- Using the right tool for the job - PentaxForums.com
You could always take a screw driver and grind it down to have 8mm prongs. Don't forget the protective eyewear when grinding or using the makeshift tool.
07-11-2021, 10:41 PM   #6
This thing seems super stuck, so those cheaper wrench things may not work. A ground down screwdriver may work well, but then I need tools to grind down the screwdriver!
07-12-2021, 07:13 AM   #7
Update:
I managed to make my own tool by filing down a door key bought from a hardware.
07-12-2021, 07:42 PM   #8
tonyzoc's Avatar
I use a needle nose pliers that I ground down the tips. Most lens span wrenches don't get close enough for those collar nuts. Some old Starrett compass deviders also make a nice tool for this, but you need a shorter one (less flex in the arms) and you still need to bring the pointed tops to make them like a screwdriver tip.
asa, nut, tool
Spotmatic F - ASA dial issue TrialOfTwo Troubleshooting and Beginner Help 4 10-18-2023 01:57 AM
Pentax K1000 and ASA dial problem Pentax1000 Troubleshooting and Beginner Help 7 09-19-2022 01:11 PM
Pentax LX ASA Dial Rolfsson Film SLRs and Compact Film Cameras 7 02-16-2019 10:59 PM
Adjust ASA dial after a couple of exposures? Gadley Film SLRs and Compact Film Cameras 4 08-14-2011 08:21 AM
ME: Trying to remove top cover but can't remove knobs Capslock118 Film SLRs and Compact Film Cameras 10 08-06-2011 11:30 AM
All times are GMT -7. The time now is 08:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
