Hello!
At the count of three repeat with me: 1, 2, 3..
IT'S ALIVE!
Ok, it turned out clunker #1 was complete and I was able to make it work. I insist there is a good amount of luck involved in this. Only swapped cosmetic parts with the others like the rewind knob bezel, bottom plate and some screws.
But just because it is alive, it doesn't mean it is in perfect working order. The curtains had no tension so I had to adjust that by eyeballing. They need to be precisely and exactly the same speed for the shutter to work above sync speed. That requires special test equipment I don't have. I got it "in the ballpark" but I'm sure 1/1000 will suffer from capping issues. I'll keep fooling around with it to get it the best I can. Also the seals still need to be worked.
But it cleaned up beautifully! Especially the gorgeous viewfinder! The frame counter is now working properly. Still need to dry test with a lens but no issues expected.
Both flash ports work.
Enough words. Here she is: (Video after the pics)
Rising from the ashes like a Phoenix!
Just love that clean viewfinder
READY TO SEE THE WORLD AGAIN!
The usual 1 minute quick test video
If it could talk!
It is at least 58 years old at the moment of this post!
Thanks,
Ismael
