Originally posted by UncleVanya A question about negative vs slides: how do you correctly invert the colors if you digitize via DSLR method?
"Correctly" is the operative word, here.
Darktable has the "Negadoctor" module, RawTherapee has the "Film Negative" module. They work to some extent. For Lightroom, there's a commercial product called "Negative Lab Pro" which, IMHO, is fantastic and does the job properly. It's extremely popular for that reason.
Alternatively, you can simply invert the tone curve and set white balance off the unexposed border in whichever raw conversion software you're using, or convert the file to TIFF and do the same in an image editor like Photoshop or GIMP. However, that's where the "fun" starts (and I say "fun" in quotes because it's not much fun at all
). The colour of the film stock affects every colour and tone in the negative, and hence the positive when the tone curve is inverted. In the colour negatives I've tried to convert in this way, there's a noticeable green tint to positives, and simply reducing saturation of green in the positive (or magenta / red in the negative) doesn't work effectively. I've had best results in GIMP, by boosting the red channel curve in the positive image, and can get something that's vaguely starting to look right, but it's far from the result Negative Lab Pro is capable of. Negative Lab Pro uses camera-specific dcp profiles, and actively removes the orange/brown colour of the film stock...
