Originally posted by titrisol Les, the Ion Slides2PC scanner I had, only gave 2592x1680 resolution
The results were not bad after trial and error on scanning (the longer you leave the slide in the scanner the better)
Negatives were very grainy though
I'm now using a Asahi bellows+slide holder now with a Macro Takumar 50/4
The resolution is much better and the tonal range I can get with a K5IIs is longer and easier to edit
The hard part is to get the 0.67 magnification needed for APS sensors.
I tried to do slide scanning with bellows and the bellows 100mm lens and a K-01.
There was much profanity involved...
The K1 solved much of that, just with the larger sensor.
The easiest way I've found for slides is with the Nikon ES-1, the K1, and the FA 50mm Macro.
That also lets you use a P-TTL flash for extra light, which you can't do with any Pentax bellows I'm aware of.
For negatives, it doesn't really hold them well, so that isn't awesome...
I'm about to try the bellows again for some negatives, once I get a happy workflow with Affinity...
-Eric
