12-07-2008, 12:55 PM   #1
LX EV Comp Wheel Repair
So the little metal ring labeling the available EV comps on the ISO wheel on my LX has come loose. I managed to grab the metal ring itself before it was lost, but now I'm considering how to reapply it. It appears it was initially pasted on, but recent threads mentioning the horrors of what certain glue vapours can do to optical surfaces has got me second guessing what type of adhesive would be best employed. Cyanoacrylate based glues seem to be out due to their glass fogging tendencies and fragility at low temperatures (my LX regularly sees extended use in -40C temperatures). Does anyone have any recommendations on what kind of adhesive to use or what to avoid? Any help is much appreciated!
12-07-2008, 04:24 PM   #2
ChrisPlatt's Avatar
Sounds like a job for Pliobond.
Chris
12-07-2008, 05:41 PM   #3
monochrome's Avatar
Email to Eric?
QuoteOriginally posted by GEli Quote
How about an email or phone call to Eric?
Eric Hendrickson
pentax27@aol.com
272 Shoffner Rd
Sharps Chapel, TN 37866
Fax/phone 865 278-1051
12-07-2008, 09:11 PM   #4
Ratmagiclady's Avatar
That's probably a good idea.
Likely, the best thing for the job would be some kind of contact cement that is easy to apply in a controlled fashion: you don't want anything gooshing out into the works. (I'm not sure how vulnerable that dial may be to that. )
I'm not sure what Pliobond is, but it sounds about right.
12-08-2008, 10:51 AM   #5
ChrisPlatt's Avatar
Pliobond is a rubbery contact cement for use on many materials.
It provides good hold yet remains slightly pliable when dry.
It is popular among camera repairers and hobbyists.
At Olympus we used it for many applications, including the sort of repair mentioned by the OP.
If you can't find it locally Fargo/Micro-Tools sells it.
Chris
ev, lx, metal, temperatures, wheel
Why does EV comp not work in K-x? MichaelA Pentax DSLR Discussion 19 02-13-2010 11:44 AM
P5 Exposure Comp. Halco Pentax Film SLR Discussion 0 10-27-2009 07:08 PM
Difficulty with exp. comp wasim_altaf Troubleshooting and Beginner Help 15 07-22-2009 04:04 AM
EV Comp in Manual Mode NeverSatisfied Photographic Technique 26 01-29-2009 08:21 AM
All times are GMT -7. The time now is 01:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
