Originally posted by yanix03 Thanks! Not a lot of noob friendly instructions out there for the A bodies. Any tips for the rubber covering on top of the film advance? I've seen vids where people cut the rubber tops open.
No, don't cut it. It's glued on so you could put a tiny bit of isopropyl alcohol around the edge of the cap, then work a thin blade under it to loosen it. Maybe an exakto-knife or a needle or a thin blade screw driver. Here are some of the tools I use pictured. Then include a JIS screwdriver set, a set of Starrett screwdrivers, a fiberglass brush for cleaning electrical contacts, tweezers, exakto-knife, oil pen, and Pliobond glue.
---------- Post added 01-07-22 at 06:46 AM ----------
I forgot one other area that's tricky...
Around the shutter release/mode dial. Again, you need a properly sized span wrench to remove the inner locking collar. It unscrews counterclockwise and is very easy to mark-up so a proper sized tool is needed or else it can get scratched up easily. Once that collar is unscrewed be very carefully lifting it off because under it is a small spring load ballbearing. I usually set the camera to Auto before removing. If I remember correctly, when in Auto the ball is free to pop up. Take note/picture of the position of the dial top so you can put it back correctly. The mode dial is very similar on the ME Super.
---------- Post added 01-07-22 at 06:57 AM ----------
BTW...I forgot about this Super Program I have pictured. It's got a shutter problem, 1/1000th and faster are capping...first curtain is sticking a bit and second curtain is catching up and closing. It needs a good CLA to fix it and I have 2 other Super Programs so I'm not going to fix it. The focus screen is pretty clean and you can have this body for the price of shipping if you'd like.
