12-26-2008, 06:30 AM   #46
QuoteOriginally posted by Mike Cash Quote
When two will do the trick, the number at home on the shelf really doesn't matter.
Quote of the day for me. I doubt anyone here will argue that.
You know, I bought some M lenses thinking I would eventually end up with enough K-mount film bodies to make it worthwhile. As it is, I only have an ME. Using M lenses on digital is (to me, anyway) annoying and I'd rather just use my Takumars.
So I have ended up with K20D, K100D, Spotmatic ESII, and SV......all of which either actually are M42 bodies or which get used by me as though they were. And the only reason I haven't used my ME yet as an aperture-priority M42 body is that the ESII fills that function, does it with open-aperture metering, and has more features to boot.
That a camera can use K-mounts is not something I think of as an appealing feature. I'm far more likely to base further acquisitions on what can make best use of my Takumars.
I wish I could enjoy Takumars as much. Though I'm happy with the lone Takumar I have, the adapter ring I bought from B&H is a pain to use (one of those Bower adapters), and I feel like I'm slowly damaging the lens mount on my K200D each time I take it off. I just wish Pentax would continue to sell their original M42 adapters.
12-26-2008, 09:45 AM   #47
jgredline's Avatar
QuoteOriginally posted by vinzer Quote
I found out the hard way to stick with the ''PENTAX'' made one and all is good on planet earth.
I have spent thousands of dollars on my equipment and yet I chose one of those bower things because it was 10 bucks cheaper than the pentax one. What I got was a lens that would not focus to infinity, in spight of the fact they said it would, It was a pain to get on and off, it cost me a month of headaches with the exchanges and ultimatly I ended up breaking it off my K1000 and thankfully I did no damage...
12-26-2008, 09:50 AM   #48
edl
They still do - the Pentax web store has them in stock.
PentaxWebstore Mount Adapter B (35mm Screwmount to Bayonet)
12-26-2008, 09:58 AM   #49
edl
Either I'm dumb or don't read the forums enough, but I only recently realized that Takumars and other screwmounts can utilize Av mode, whereas you have to live with green button metering on K and M lenses. I find Av and preset apertures much easier to use than the often inconsistent green button metering.
I've used my J9 and Super Takumar 35/2 much more in the last two weeks after this revelation. The Tak puts out some great results! I think I'll grab a 28/3.5 and 55/1.8 next.
12-26-2008, 10:41 AM   #50
Nick Siebers's Avatar
hi edl
Maybe it is just me, but I find I need to up exposure at least a stop, usually 1.5 when using Av and a Tak. Not sure why, but it helps. Do you adjust in this way? Anybody?
12-26-2008, 12:13 PM   #51
Banned
QuoteOriginally posted by Nick Siebers Quote
hi edl
I think the general consensus is yes. but not for all lenses. my Takumars on the telephoto end most surely need it, where as most of my standard length lenses dont. I can use AV with my 55 and never have to adjust EV. this may not be the same case for everyone though.
that's because you can stop down a Takumar manually by using the auto/manual switch. a manual K series does not allow for that. and I agree abouut the presets. I just recieved a preset 300mm and I found out very quickly how valuble that is for AV and proper focusing.
12-26-2008, 12:24 PM   #52
edl
QuoteOriginally posted by Nick Siebers:
Hey Nick, I usually use +0.7 to +1.0 on my Tak 35/2, +0.4 on my J9 85/2.
But in general I'm usually +0.4 to +1 using various lenses on both the K10 and K20, using center weighted average metering.
I find that metering in Av mode with screwmounts much more consistent and predictable than green button metering with K MF lenses. Nevermind the Taks have such beautiful build quality.
QuoteOriginally posted by séamuis Quote
Precisely - back when I was first learning film I had a CZ T135/3.5 that worked the same way. At first I thought it was annoying, but I like how you can focus wide open, and then stop down until you find the DOF that you want. Snap, done!
But of course the K and M series lenses are good with the K and M bodies, so I'll keep them around.
12-26-2008, 06:09 PM   #53
QuoteOriginally posted by edl Quote
That's just what I need, but it doesn't seem like they ship to anywhere else aside from the US. Good to know they're still in stock, though. Maybe I can try to force the local distributor to get me one. Hope they do.
Thanks for this great piece of information.
QuoteOriginally posted by jgredline Quote
I'm also seeing that with the adapter I got - cannot focus to infinity. Well, at least I got a Spotmatic to tide me over until I can find a way to source the original adapter. I didn't even bother to have it exchanged, since the cost to UPS the darn thing from here might even be more expensive than the adapter itself.
Mine is even more screwy since the final position of the lens is off by a quarter circle, so the aperture selection which should end up on top of the mount ends up on the right side, making aperture selection and turning the auto switch on and off very, very difficult, it's almost laughable.
You're not alone. That's the first time I've read about that. I'll give that a whirl once I can get my hands on an original Pentax adapter. Good info.
12-26-2008, 10:04 PM   #54
jgredline's Avatar
I shot another roll of BW400CN film today with ole Spoty. This fellow is growing on me. Drove 125 miles to the Angeles national forest to find some snow. My kids who are 9 have never seen snow before. I also shot a roll of fuji velvia 100 with my ME SUPER and I love it!!!!
I have discovered the the model of Spotmatic I have, the 1964 version's internal meter only moves at full stops! So basically, I ignored the internal meter and went via the sunny 16 rule and for those tricky shots I used an external light meter.
12-26-2008, 10:09 PM   #55
jgredline's Avatar
Here are a few with the ME Super.
12-27-2008, 08:32 AM   #56
Wonderful shots there, Javier. Kudos.
I have to reacquaint myself with the sunny f/16 rule and hone my guesstimation skills. Seems like I rely too much on DSLR metering nowadays. It would be nice to not have to whip out the external light meter for each and every shot I take with film bodies.
12-27-2008, 07:16 PM   #57
jgredline's Avatar
Thanks Vinzer. I missed the exposer on the black and whites by a tad, but next time I know how to set it up. User error more than anything.
12-28-2008, 07:04 AM   #58
Banned
using my spotmatic has pushed me to get a hand held meter. I always find myself setting up shots and just generally moving slower with my Spotmatic, so I think a meter would be a great thing to have.
12-28-2008, 07:41 AM   #59
I recommend quite highly the Sekonic Flashmate 308s. It does a beautiful job of metering both ambient and incident, and it is a flash meter as well. It really is the best meter I've ever used and I picked it up for < 125.00 used but like new on eBay. Fits nicely in a shirt chest pocket, and it goes everywhere with me.
woof
12-28-2008, 07:42 AM   #60
Banned
QuoteOriginally posted by woof Quote
woof
thank you very much for the recommendation, I will look into that today.
spotmatic
For Sale - Sold: Spotmatic, K1000, Sigma 24-70 2.8 dg and more (US/CAN) Andrew Lang Sold Items 0 08-10-2010 06:55 PM
Spotmatic SP II Brianog Pentax Film SLR Discussion 7 02-22-2010 09:30 PM
For Sale - Sold: K1000 bodies, ME Super Body, Damaged K1000 SE Body Rustyoldbug Sold Items 7 11-11-2009 08:48 AM
spotmatic zac1121 Pentax Film SLR Discussion 8 07-23-2009 10:13 AM
Spotmatic F Vs Spotmatic ES 3RiC Pentax Film SLR Discussion 14 05-26-2009 06:08 AM
All times are GMT -7. The time now is 03:36 PM. | See also: NikonForums.com, part of our network of photo forums!
