12-24-2008, 09:13 AM   #1
Setting ISO 160 on analog dial?
Just want to confirm this, if I load up my LX with Fuji 160C film, I'd set the ISO at the 2nd dash between 100 and 200, right? I'd presume the first dash would be 1/3 over (likely 125 films), and the 2nd dash 2/3's (160). Not exactly correct, but close; there's no half stop option.
Only shot full-stop rated films before.
12-24-2008, 09:36 AM   #2
Ratmagiclady's Avatar
That works, you should be fine. If it's color negative film, I'd often rate it a third of a stop lower, anyway. depending what it is.
12-24-2008, 11:02 AM   #3
Wheatfield's Avatar
QuoteOriginally posted by CSoars Quote
Lets see if I can remember this:
12, 16, 20, 25, 32, 40, 50, 64, 80, 100, 125, 160, 200, 250, 320, 400, 500, 640, 800, 1000, 1250, 1600, 2000, 2500, 3200, 4000, 5000, 6400.
IIRC, This is the full numbering sequence on an ISO dial.
12-24-2008, 11:29 AM   #4
Sluggo's Avatar
Yup, in an exponential as opposed to linear sequence, 125 and 160 really are 1/3 and 2/3 of the way between 100 and 200. Well, almost. I think it's strictly closer to 126 and 159.
12-24-2008, 03:24 PM   #5
Thanks! I'm wondering how it'll scan compared to superia 200 (consumer grade). Supposedly it's a punchy saturated film, which should minimize any need for PP.
12-24-2008, 03:28 PM   #6
No idea. My mention of rating c-41 a third of a stop under at least used to be pretty conventional wisdom, but that's way old, and I gather most scanners actually like thinner negs.
You maniacs!
dash, films, iso
Problem with setting ISO on new White K-x whbroker Pentax DSLR Discussion 5 04-15-2010 10:03 AM
K-x high ISO setting? tokyoso Pentax DSLR Discussion 10 02-23-2010 11:34 AM
program a iso dial.... echospace Pentax Film SLR Discussion 3 07-30-2009 07:18 PM
Does anybody know how to fix the ASA/ISO dial on a Super Program? pasipasi Pentax Film SLR Discussion 1 08-26-2008 03:01 PM
Firmware1.10 ISO setting by dial Question ? pcarfan Pentax DSLR Discussion 5 09-16-2007 08:37 PM
All times are GMT -7. The time now is 03:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
