Originally posted by monochrome Blue -> Working on it. I certainly won't have anything as dramatic as Steve posted. Additionally, there was conern about some banding and exposure issues with the Sightseer and I was prepared to send it to Eric for an evaluation. If these posts are indicative there is no problem. I have an outing planned for Sunday, then the groiup needs to agree (or I will just make a leadership decision and assert a place and time
I WILL post here and to Flickr - but local processing is iffy.
I had PM'd Monochrome regarding the negatives I got back from the Sightseer. Most of my original scans were obviously OOF for the entire image with "shadowing" on the edges of the frames. I suspected that the pressure plate was not holding the film flat. As it turned out, I was partially correct. My film came back rolled and uncut from the processors. Apparently the negatives were too "curly" and loaded improperly into the scanner. The result was that the negative was buckled during the scan.
I sent the PM suggesting caution based on my results and rescanned the negs the next day after they had a chance to relax flat in their sleeves. The rescanned versions looked much better and lacked the "shadowing" on the edges. Despite the improvement, I still found that the scans were not as sharp as I would have liked and that I have come to expect from the lenses used. Because of the softness, most of the images I posted here have a fair degree of sharpening applied where I have not had to do this in the past.
I sent a follow-up PM to Monochrome indicating the improvement, but still registering my concern that the film might not be flat inside the camera. It might just be my imagination, but I thought it would be good to check the body and make sure that the back is not sprung and that the pressure plate engages the film rails. It would be a shame for people to put a lot of effort into taking good pictures only to get a roll of fuzzy pics back after the camera has moved on.
P.S. Ektar seems to have a very thin film base. It may be that the older bodies may have a more difficult time holding it flat. Here is an article discussing the subject...
http://www.astropix.com/HTML/I_ASTROP/FILM/FOCUS1.HTM
