01-13-2009, 05:08 PM   #1
Fast film
I'm looking for recomendations for film in the 800 range. For B&W I'm thinking HP5 pushed 1 stop in microphen, any other ideas? For color is it better to use 800 speed, or push 400?
Thanks for any ideas, Ryan
01-13-2009, 08:21 PM   #2
Colour negative films can't be pushed well, so you should use some 800 film.
QuoteOriginally posted by ryno Quote
01-13-2009, 09:03 PM   #3
i've been using PRess 800 aka Superia 800. can be bought at about $3 a roll at B&H. stuff seems great to me, not overly saturated, but from my tests the reds seem to come out a bit too strong.
01-13-2009, 11:08 PM   #4
ryan s's Avatar
HP5+ pushed sounds like it'll fit just fine
01-14-2009, 01:00 AM   #5
titrisol's Avatar
Location: In the most populated state... state of denial
Pushing HP5 or TriX sounds like a good idea. Developed in Xtol or DDX it is fine.
Can you get your hands on some Neopan 1600? That one is a great film, you can shoot it as 1,000 or so
01-14-2009, 03:29 AM   #6
Lowell Goudge's Avatar
Years ago, I regularly used Tri-X and shot at either 1600 or 3200 ISO.
I would put this in my KX with a 50mm F1.4 and shoot in the middle of the night at 1/30 of a second.
Peole just ignored me because they could not believe anyone would take a photo without flash. It made for some great shots.
I have posted these ones previously, scanned from the negative with a minolta Dimage II scanner.
Note to develop Tri-X in the developer (D76 if memory serves me correctly) requires about 5:50 for normal processing, but 32 minutes for ISO 3200 (at 20C)
https://www.pentaxforums.com/forums/383094-post12.html
01-14-2009, 09:07 PM   #7
Ratmagiclady's Avatar
I rather like Tmax P3200, actually, (nicer rated at around 2000 or so) Goes nice in its own developer, anyway. I may give D76a whirl, soon.
01-14-2009, 09:28 PM   #8
I ordered some fuji 800 and HP5 tonight. Thanks for the ideas.
Ryan
01-14-2009, 09:47 PM   #9
They've changed the formula of Tri-X god knows how many times since then, Lowell. The ISO 3200 dev times, in straight D-76, are down to about 15 minutes at 20C.
As always, check the Tech Pubs for films. Tri-X's is F-4017.
New Tri-X's time doesn't even reach 20 mins in 1:1 D-76 at 3200!
Keep in mind that Tri-X has one stop positive latitude - you can shoot it at ISO 800 without push processing it at all.
I love pushing Tri-X to 3200...but I don't expect to get away with street shots like Lowell (people are far too aware of technology these days, and are more likely to assume you've got some fancy high-tech low-light camera.)
And remember, for every roll of Ilford Delta 3200 or TMAX P3200 you buy, you could've bought two rolls of Tri-X, and get similar results. I don't find the grain too intrusive; I've found my shots on Tri-X @ 3200 look less grainy than some others on Neopan 1600 or TMAX. But that depends on your scanner and dev, more than anything.
01-15-2009, 07:58 AM   #10
QuoteOriginally posted by lithos Quote
Admittedly, I got a good deal on my last batch of p3200.
01-15-2009, 08:28 AM   #11
Douglas_of_Sweden's Avatar
Fuji Neopan 1600 used to give way better results than T-MAX 3200.
Pushing Tri-X or T-Max 400 one or two steps is also very reasonable solutions.
You can influence the grain size by changing the temperature away from the standard recommendation, but mind you it will also change the development time, so you will have to experiment a bit.
01-15-2009, 02:26 PM   #12
QuoteOriginally posted by Douglas_of_Sweden Quote
I never tried the Neopan 1600, myself. I believe a friend has some, but I don't know if he's used it yet. I used to push a whole lot of stuff, though. In fact, I'd often take it to extremes.
I dont *generally* recommend going off temperature, though, generally all that does is bump contrast (not generally what I need more of) and raise grain. I figure, if you're going to do that, you probably may as well have the speed, as well. (But I'm kind of a low-light person, most of the time, as the rodentey name may imply. If I want nice grain and I can have slow film in, I like good old Plus-X. Though I've been playing with Neopan Acros here and there. (and trying to get the contrast down a notch, though it is in fact very sharp)
Come to think of it, Douglas, have you ever tried pushing Neopan 400? I've been playing with this stuff recently, and finally gotten back around to some nice results with good old D-76, full-strength. Though I haven't tried pushing it. I had this period where all I had was Tmax developer, and this copy of Rodinal I've been not-wanting to mix till I know we aren't moving away at any given month.
I'm *trying* to prevent big proliferation of films and developers at least for now. I don't do that much quantity.
01-15-2009, 04:04 PM   #13
QuoteOriginally posted by Ratmagiclady Quote
I'm trying to dig into my memories, and should probably go get the negative-files in the storage room where there is of course notes for each film. You see, I almost grow up in a dark room since my dad taught me how to develop my own films when I was six. Sure I didn't do it on my onw until a bit later. Then I kept on doing it year after year...did military service as photographer...decided not to go pro...but stayed on a relatively advanced amateur level...headed a camera club...built my own dark room in my first appartment...got married...and somewhere were the kids came my dark room gear was stuffed away in some boxes. Last time we moved I had to throw away a load of way to old chemicals. Then came digital age. I sometimes shot some colornegatives as a complement, no black and white.
But then I got a decent negative scanner, thinking I should scan lots of old negatives and slides (still has a mountain of Kodack carousel slide magazines in a wardrobe), and last summer I could not resist puting a BW in my super-A again and of course I couldn't stop. Its not as bad as it used to be, probably had FSA (Film Shooting Addiction) back then, but it's approaching a point where I need to find my old gear to develope films, since it has become so costly to develop BW. That should not be so hard to get running again in the washing room.
Anyway: as far as my memory serves me, I used to push Neopan 400 up to 1600. Above that it didn't work very well. I think I managed to get the grain down by lowering the temperature, and I believe I used D76. But if you have patience with me I can dig up my notes during the weekend.
As far as I remember, I generally had the impression that Neopan had less contrast but more detailed grey scale than T-max. So I picked film according to the conditions. Does that makes sence to you, does it fit your experience?
I used to shoot both T-max 100, 400, Tri-x, occasionally Plus-x, all loaded form these large 30 m rolls you could buy and load yourself. Fuji Neopan was another matter, because my parents happened to have a neighbour who was salesman for Fuji Film ...so I could afford buying them pre-loaded so to say.
I did use some Neopan 1600 and was more hapy with the results than the T-max 3200. But often it worked just as well to press the 400 ASA films to 1600. Done many concerts with that.
Must get started scanning some of my old favorit shots in BW.
01-16-2009, 07:36 AM   #14
I don't disagree
I did these shots in 1985.
01-16-2009, 12:29 PM   #15
Cool, Douglass.
You may just have that the other way around, actually. I could *get* some contrast out of Tmax, but it always seemed a bit flatter, with the exception of that P3200 stuff. I think they may have changed the Tmax 400 since I last had any, though.
The Neopan, in general, I've found pretty constrasty, but overall good stuff. I had been about to go back to HP5, nonetheless, until I tried the Neopan 400 in D-76: this looks promising. I'm looking forward to getting these under the enlarger, actually. (Right now it's a little cold for the wet side of my darkrooom, )
film, ideas
120 fast film? lbenac Pentax Medium Format 21 08-11-2010 05:30 PM
What's a FAST (used to be fast) film lens neverbnnba Pentax SLR Lens Discussion 11 07-03-2010 05:42 PM
Recommend a fast color print film? Mister Pita Film SLRs and Compact Film Cameras 15 07-03-2010 04:59 PM
What is "Fast" about the fast Fifties... jess Pentax SLR Lens Discussion 11 01-04-2009 05:18 PM
A Fast Fifty Is Really A Fast 75mm drewdlephone Pentax SLR Lens Discussion 182 12-08-2008 10:38 AM
All times are GMT -7. The time now is 02:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
