Well I finally got a roll through my
"new' Spotmatic... with mixed results (mostly bad, truth be told)... I shot Fuji Superia X-TRA 400 because that's what was readily available at the local drug store and I heard some people like it in
this thread. What I didn't consider is that the Spotmatic shutter speed only goes to 1/1000 sec. so I had to stay stopped down to f/11 or f/16 out in the sun which is where I was shooting most of the time... I'm such a noob on film
(even though I used to shoot it a bit).
It seems I need new light seals, so over half the shots have big low-contrast areas (or worse)... some don't - maybe I didn't orient the camera in a bad direction when they were near the leak?... There are scratches on the negatives - is that usually caused by something in the body or at the lab? I'm pretty unimpressed with the local Longs Drug stores lab, but maybe I need to talk to those guys - scans I got were tiny 1818x1228 is that typical?
Ok... Here's a few of the better shots...
(no post processing unless noted)
with the Auto-Takumar 35/2.3
What I think is the light leak is really visible in that last one in the lower left corner.
with the Takumar 135/3.5 preset
135/3.5 preset (exposure brightened a bit in Lr but that's fair right? - I used to do that with the enlarger...)
with the Super Takumar 55/1.8 (I think)
and a minute later with the K20D + DA*50-135
(contrast and exposure adjusted to approximate the results from the film camera...
I only chimped the rear of the came a couple times
