02-08-2009, 06:56 PM   #1
Replace parts
i have a Pentax ME and the Exposure Compensation Dial is tilted (i think it was dropped in its head). i just bought a camera just like it on ebay for replacement parts. i was able to remove the Film Rewind from both cameras but not the Dial. How do i extract this part? seems imposible.
any help is greatly appreciated. going crazy without my camera.
02-08-2009, 07:09 PM   #2
Moved to the correct forum.
02-08-2009, 11:33 PM   #3
titrisol's Avatar
Location: In the most populated state... state of denial
check here for Dissasembly of the ME Super, should be the same as the ME
I think I have the service manual for the ME Super in pdf, send me a PM or an email and I'll send it back if I can find it tonight
02-09-2009, 02:04 PM   #4
from what i see in the pictures the dial slides off. its definitely not that easy. maybe you can see something different. its in the middle of the page Disassembly of the Pentax ME Super Camera
02-09-2009, 02:38 PM   #5
There is a special nut that holds the dial in place. It will have a small notch on each side and fits around the center shaft. It can be removed with needlenose pliers .
02-09-2009, 02:47 PM   #6
Here is the dial with the retaining nut set as it would be on camera.
02-09-2009, 03:47 PM   #7
its impossible. theres two little notches on each side under the outer ring...and a wire that i can move inside the center shaft...
i would send it to Pentax but they dont even know if they can fix it.
02-09-2009, 04:17 PM   #8
Can you post a photo?
02-09-2009, 07:34 PM   #9
QuoteOriginally posted by Catelin Quote
I'll bet Eric can. Eric Hendrickson
02-09-2009, 11:43 PM   #10
Just1MoreDave's Avatar
The little notches accept a tool called a spanner. But you can easily improvise something, as long as it fits the slots. Something like needlenose pliers or tweezers with the tips ground down or dividers or two small screwdrivers.
camera
What to replace my Samsung GX-20 with? theperception2008 Pentax DSLR Discussion 8 03-10-2010 03:36 PM
K-7 replace K20d? or not? gemini Pentax DSLR Discussion 50 06-03-2009 04:30 AM
Would you replace a 16-45 with the 18-250? jmdeegan Pentax SLR Lens Discussion 16 02-02-2008 07:16 AM
Giving up the 16-45. what should replace it? jazzman Pentax SLR Lens Discussion 11 12-21-2007 02:50 PM
All times are GMT -7. The time now is 04:01 AM. | See also: NikonForums.com, part of our network of photo forums!
