Closed Thread
10-10-2010, 10:17 AM   #211
Ole
Ole's Avatar
I have updated the database with all data received so far. The results are attached as pdf files to the first post in this thread:
https://www.pentaxforums.com/forums/pentax-film-slr-discussion/51190-k1000-se...tml#post490307
10-11-2010, 04:03 PM   #212
Moe49's Avatar
Model: K1000 SE
Color of faux leather: Brown
Serial number: 6047211
Location of serial number: Bottom plate stamped
Asahi Optical logo on prism housing: Yes
Asahi name above Pentax name on prism housing: Yes
Asahi Opt. Co. engraved on back side of top cover: Yes
"Bump" on top plate near rewind crank: No
Top plate: Metal
Bottom plate: Metal
Battery cover: Threads
Manufactured/assembled in: Unknown
Location of manufacturing/assembling information: N/A
Focusing screen: Split prism with microprism collar
Weight (without batteries and body cap) (if you know): 620g
Year of original purchase (if you know): Unknown
10-15-2010, 06:59 AM   #213
Model: K1000
Color of faux leather: Black
Serial number: 7431895
"Bump" on top plate near revind crank: No
Top plate: Metal
Bottom plate: Metal
Manufactured/assembled in: No information
Location of manufacturing/assembling information: None
Focusing screen: Microprism
Weight (without batteries and body cap) (if you know): unkown
Year of original purchase (if you know): unknown
This lens came with a Pentax SMC-M 50mm, f/2 lens. I believe that the husband of the lady I bought this from was the original owner. This lens would put the original manufacture/purchase date sometime in the early eighties, as that is when the M-series cameras/lenses were in production.
10-15-2010, 10:15 PM   #214
This is my Pentax K1000 SE
Serial number: 6057734
Location of Serial number: Bottom plate insert
Asahi optical logo on prism housing: No
Asahi name above Pentax name on prism housing: No
Asahi Opt. Co. engraved on back side of top cover: No
" Bumb" on top plate near rewind crank: No
Top plate: plastic
Bottom platelastic
Battery cover: bayonet
Assembled in: China
Location of assembing information: Bottom plate sticker
Focasing Screen: Split screen with microprism collar
Weight : don't know
Year of manufacture: don't know
10-21-2010, 06:35 PM   #215
Ubuntu's Avatar
Model: K1000
Serial number: 7785273
Top plate: Metal
Bottom plate: Metal
Weight (without batteries and body cap) (if you know): 1 million pounds
Year of original purchase (if you know):1986
This camera came with an SMC Pentax-A 50mm f/2 lens.
10-21-2010, 06:40 PM   #216
Just so you guys know, future entires should be posted here: https://www.pentaxforums.com/forums/pentax-serial-number-database/?do=addserial&itemid=275
(since we now have a dedicated database just for serial numbers)
11-16-2010, 05:33 PM   #217
I see another difference that no one else may have noticed: the collar around the rewind crank.
If you look at the pictures posted by notsowise above, you'll notice that the part of the top plate around the rewind crank is chrome and stepped and apparently an integral part of the body, where the part I'm accustomed to seeing (and depicted here on Bojidar Dimitrov's excellent website) are painted black the same as the cap of the film counter and shutter speed dial and one smooth, relatively shallow slope. It's an extra piece that fits onto the top plate. My guess is that the type shown in notsowise's picture is a later modification to reduce cost, whereas the version in the second picture is the earlier version.
edit: Looking at it again, it seems that the difference I noticed seems to be a consequence of having a plastic top plate, as the K1000 posted by notsowise has a plastic top plate.
11-17-2010, 08:52 AM   #218
builttospill's Avatar
Yes, on earlier models the black piece you're discussing was metal. It was later changed to a lightweight plastic.
I recently purchased two SEs in good shape to replace some parts of an older brown SE (all metal) I've been fixing up. The two newer SEs had the AOCO logo stamped in the top plate, but the black piece was plastic, along with quite a few other parts that are metal in the older brown one. There were other changes made too, to simplify the design and reduce cost. There are benefits though, it was much easier to disassemble the newer bodies due to some of these updated parts.
03-15-2011, 09:32 PM   #219
pgoat's Avatar
Model: K1000
Serial number: 7847146
Top plate: Metal
Bottom plate: Metal
Manufactured/assembled in: "Body Assembled in Hong Kong"
Location of manufacturing/assembling information: Sticker on bottom plate
Weight (without batteries and body cap): 700 grams
Year of original purchase (if you know): purchased ca. 1988, probably used, as it came with a Ricoh lens (Rikenon XR S 50mm f/2, S/N 196978)
05-13-2011, 01:54 PM   #220
ghl
ghl's Avatar
Model: K1000
Serial number: 8284977
Top plate: Metal
Bottom plate: Metal
Manufactured/assembled in: no clue
Location of manufacturing/assembling information: none
Year of original purchase (if you know): 1987
05-22-2011, 11:18 AM   #221
Model: K1000
Serial number: 7732028
"Bump" on top plate near revind crank: No (it has a screw, though)
Top plate: Metal
Bottom plate: Metal
05-28-2011, 06:29 PM   #222
Model: K1000
Serial number: 6931600
Top plate: Metal
Bottom plate: Metal
Focusing screen: Split screen
Weight (without batteries and body cap) (if you know): N/A
Year of original purchase (if you know): N/A
08-09-2011, 12:40 PM   #223
Don From The Radio's Avatar
Model: K1000
Serial number: 8471294
Location of serial: Bottom plate engraved
Asahi Optical logo: No
Asahi name on prism: No
Asahi Opt. Co engraved on back side: yes (No country of origin)
Top plate: metal
Bottom plate: metal
Battery cover: threads
Manufactured: Sticker is worn out
Location of manufacturing info: Sticker on bottom plate, completely worn out
Screen: Microprism
Weight: Unknown
Year of original purchase: Original owner claims 1990
08-25-2011, 01:02 AM   #224
Model: K1000
Serial number: 6204560
Asahi Optical logo: Yes
Asahi name on prism: Yes
Top plate: metal
Bottom plate: metal
Manufactured: None
Location of manufacturing info: No info.
Screen: Split prism with microprism collar
Weight: Unknown
Year of original purchase: Unknown
Images courtesy of Frank Feng Wei (The person whom I bought the camera from)
10-02-2011, 09:28 AM   #225
I have two K1000's!
First Camera
Model: K1000
Serial number: 6133808
Asahi Optical logo: yes
Asahi name on prism: yes
Asahi name on back of top cover: yes
Top plate: metal
Bottom plate: metal
Battery cover: threaded
Assembled in unknown
Focussing screen: Split prism with microprism collar
Weight: Unknown
Date of purchase: Unknown, but likely the early 1980s
If it helps, this camera came with SMC P-A 1:2 50 mm (early version) serial number 2033704
Second Camera
Model: K1000
Serial number: 7808811
Top plate: metal
Bottom plate: metal
Weight: Unknown
This camera came with SMC P-M 1:2 50 mm (early version) serial number 4396106
Closed Thread
asahi, bottom, data, database, information, k1000, metal, plastic, plate, screen
Lens Serial Number Database Ole Pentax SLR Lens Discussion 57 04-17-2016 09:58 AM
DA* 16-50mm Serial Number Database. Buddha Jones Pentax SLR Lens Discussion 528 06-13-2012 01:11 AM
Serial Number Database royal07 Pentax SLR Lens Discussion 1 10-15-2010 05:04 PM
Serial Number dating John Araki Photographic Technique 2 08-28-2008 11:13 PM
All times are GMT -7. The time now is 10:30 AM. | See also: NikonForums.com, part of our network of photo forums!
