Closed Thread
02-21-2009, 12:50 PM   #31
zplus's Avatar
QuoteOriginally posted by zplus Quote
Year of original purchase (if you know): Do not know
Update: Year of original purchase (if you know): 1981 or 1982
02-21-2009, 02:09 PM   #32
[Here's another unique one. There is no sticker - it is engraved " Body assembled in Hong Kong" Serial # is 7579852
Has bump, is all metal and says Asahi Optical, Co on back of top cover
Charlie
02-21-2009, 02:51 PM   #33
The camera I posted on the other thread is from E-bay so I can't confirm wether or not it has a sticker or not.
The K 1000 appears to have had concurrent assembly locations throughout the 70's.
I have 3 more k 1000's but they are from the 80's -
Charlie
02-21-2009, 05:30 PM   #34
Lens Buying Addict
monochrome's Avatar
Ole: In the spreadsheet (database) you have transposed digits 2 and 3 of my serial number. You entered 7498714 the actual number is 7948714
From an old ebay TurboLister backup file - dk if I can find the actual images
Model: K1000 SE
Color of faux leather: Brown
Serial number: 7947814
Location of serial number: Bottom plate stamped
Asahi Optical logo on prism housing: Yes
Asahi name above Pentax name on prism housing: Yes
Asahi Opt. Co. engraved on back side of top cover: Yes (no Japan)
Top plate: Metal
Bottom plate: Metal
Battery cover: Threads
Manufactured/assembled in: No information (glue present, sticker removed)
Location of manufacturing/assembling information: Bottom plate sticker (removed)
Focusing screen: IIRC Split screen with microprism collar
Weight (without batteries and body cap) (if you know): no information
Year of original purchase (if you know): no information
02-21-2009, 06:42 PM   #35
Ole
Ole's Avatar
Monochrome, thanks for checking. I have fixed the mistake.
02-21-2009, 06:53 PM   #36
maybe you should sticky this so it doesn't get lost
02-21-2009, 07:32 PM   #37
Lens Buying Addict
monochrome's Avatar
QuoteOriginally posted by Ole Quote
Uh, I was moving fast and forgot the Hope I didn't sound too terse
02-21-2009, 07:49 PM   #38
Ole
Ole's Avatar
I like terse! Thanks for the help!
03-05-2009, 01:41 PM   #39
Model: K1000
Color of faux leather: Black
Serial number: 7562952
"Bump" on top plate near revind crank: No
Top plate: Metal
Bottom plate: Metal
Location of manufacturing/assembling information: None
Focusing screen: Microprism
Weight (without batteries and body cap): Unknown
Year of original purchase: Unknown
03-07-2009, 10:29 AM   #40
Would like to figure out year model, please
Model: K1000
Serial number: 6714159
Asahi Opt. Co. engraved on back side of top cover: No
Top plate: Metal
Bottom plate: Metal
Manufactured/assembled in: Hong Kog
Location of manufacturing/assembling information: Bottom plate sticker that reads "BODY ASSEMBLED IN HONG KONG"
Weight (without batteries and body cap) (if you know): around 608 gramas
Year of original purchase (if you know): Wish I knew; am hoping to find out what year it was made!
03-07-2009, 11:12 AM   #41
Model: K1000
Serial number: 7555566
Top plate: Metal
Bottom plate: Metal
Manufactured/assembled in: XXX
Location of manufacturing/assembling information:XXX
Focusing screen: XXXX
Weight (without batteries and body cap) (if you know): around XXX gramas
Year of original purchase (if you know): XXX
03-07-2009, 06:45 PM   #42
Model: K1000
Serial number:8117109
Top plate: Metal
Bottom plate: Metal
03-08-2009, 05:24 AM   #43
Model: K1000
Serial number: 7645004
Location of serial number: Top plate engraved
Asahi Opt. Co. engraved on back right side of top cover: Yes
Top plate: Metal
Bottom plate: Metal
Manufactured/assembled in: Unsure
Location of manufacturing/assembling information: Unsure
Year of original purchase: mid-70's
#2
Model: K1000
Serial number: 7990136
Asahi Opt. Co., Japan engraved on back right side of top cover: Yes
Top plate: Metal
Bottom plate: Metal
Manufactured/assembled in: Not sure
Location of manufacturing/assembling information: Not sure
Year of original purchase: Unsure
03-08-2009, 06:00 AM   #44
Sluggo's Avatar
Just acquired another.
Model: K1000
Serial number: 6541697
"Bump" on top plate near rewind crank: No
Top plate: Metal
Bottom plate: Metal
Weight (without batteries and body cap) (if you know): don't know
Year of original purchase (if you know): don't know
03-09-2009, 04:32 PM   #45
Just got another (a Goodwill find, $25 with smc A 50/2)
Model: K1000
Color of faux leather: black
Serial number: 5327476
Location of serial number: Stamped black plastic insert on bottom panel close to rewind button
Asahi Optical logo on prism housing: No
Asahi name on prism housing: No
Asahi Opt. Co. engraving on back side of top cover: No
Top plate: Plastic
Bottom plate: Plastic
Battery cover: Bayonet
Assembled/manufactured in: China
Location of manufacturing/assembly information: Bottom plate sticker
Focusing screen: microprism
Weight: Unknown
Year of original purchase: Unknown, but I suspect it to be very late in the K1000 production run
Closed Thread
asahi, bottom, data, database, information, k1000, metal, plastic, plate, screen
Lens Serial Number Database Ole Pentax SLR Lens Discussion 57 04-17-2016 09:58 AM
DA* 16-50mm Serial Number Database. Buddha Jones Pentax SLR Lens Discussion 528 06-13-2012 01:11 AM
Serial Number Database royal07 Pentax SLR Lens Discussion 1 10-15-2010 05:04 PM
Serial Number dating John Araki Photographic Technique 2 08-28-2008 11:13 PM
All times are GMT -7. The time now is 04:01 AM. | See also: NikonForums.com, part of our network of photo forums!
