Closed Thread
05-18-2009, 05:33 PM   #91
wirrah's Avatar
Model: K1000
Color of faux leather: Black
Serial number: 7611444
Location of serial number: Bottom plate stamped
Asahi Optical logo on prism housing: Yes
Asahi name above Pentax name on prism housing: Yes
Asahi Opt. Co. engraved on back side of top cover: Yes
"Bump" on top plate near rewind crank: No
Top plate: Metal
Bottom plate: Metal
Battery cover: Threads
Manufactured/assembled in: No information
Location of manufacturing/assembling information: None
Focusing screen: Microprism
Weight (without batteries and body cap) (if you know): ~620 gm
Year of original purchase (if you know): unknown
05-26-2009, 01:00 PM   #92
Yet Another
Model: K1000
Serial number: 8472374
Asahi Optical logo on prism housing: No
Asahi name above Pentax name on prism housing: No
Top plate: Plastic ? Magnet does not stick (does stick to bottom plate)
Bottom plate: Metal
Weight (without batteries and body cap) (if you know): Don't know
05-26-2009, 01:05 PM   #93
Mixed Plastic/Metal Top/Bottom plates?
Did Pentax produce K1000's with, say, a plastic top plate and a metal bottom plate?
I have one that I know has a metal bottom plate--I've removed it, and a magnet sticks to it. But the top plate shows no magnetic attraction. I know it might be aluminum or brass, but are there mixed models like that?
05-28-2009, 06:24 PM   #94
geauxpez's Avatar
Fresh from the mailbox...
Model: K1000
Serial number: 8030235
"Bump" on top plate near revind crank: No (I've never seen one)
Top plate: Metal
Bottom plate: Metal
Weight ?
Year of original purchase ?
05-28-2009, 09:23 PM   #95
My first K1000
This is the first camera I ever bought and I still use it.
Model: K1000
Serial number: 7826726
Top plate: Metal
Bottom plate: Metal
Location of manufacturing/assembling information: None (If it had a sticker, I don't remember.)
Weight (without batteries and body cap) (if you know): unknown
Year of original purchase (if you know): 1981
05-30-2009, 10:21 AM   #96
Ole
Ole's Avatar
A hybrid K1000?
QuoteOriginally posted by lawsonstone Quote
This is the first such "hybrid" in the database if the top is indeed plastic. What also makes it stand out is the absence of the Asahi logo on the front combined with the presence of the Asahi Opt. Co. engraving on the back side of the top plate.
Could it be a transition model we didn't know about until now? There is one camera more in the database (8402823) with no Asahi logo but with the Asahi Opt. Co. engraving on the back of the top plate. The user (ismaelg) in that case indicated the top to be metal.
The final run with plastic top and bottom does not have Asahi Opt. Co. engraved on the back of the top plate!
Interesting!!
05-30-2009, 06:09 PM   #97
Ole
Ole's Avatar
Database updated, we now have 72 entries.
06-01-2009, 02:53 AM   #98
geauxpez's Avatar
Did you buy this one new? A plate could have been replaced some time along the way.
06-02-2009, 12:40 PM   #99
Interesting
Okay…I have here a K1000 SN 8472374 (which I already logged above). Bottom plate is metal (not ferrous, but it clinks metallically when hit). The top plate has no Asahi logo on the front, but does have the "Asahi Opt. Co." stamp on the back below the film advance lever.
QuoteOriginally posted by Ole Quote
Interesting!!
06-02-2009, 12:42 PM   #100
I actually have one with no Asahi Opt. Co. engraving anywhere. Plastic K1000 I guess!
06-02-2009, 09:42 PM   #101
Sorry to break the pattern of year x serial number, but...
Model: K1000
Serial number: 6554978
Location of serial number: Bottom plate insert (plastic insert)
Asahi Opt. Co. engraved on back side of top cover: No
Top plate: Plastic
Bottom plate: Plastic
Battery cover: Bayonet
Assembled in: China
Location of manufacturing/assembling information: Same as assembly?
Year of original purchase (if you know): 1995 (I bought it new then)
PENTAX K10D  Photo
PENTAX K10D  Photo
PENTAX K10D  Photo
06-02-2009, 09:48 PM   #102
My "new" K1000, the one which actually made me look for age info
Model: K1000
Serial number: 7567995
Asahi Opt. Co. engraved on back side of top cover: Yes (NO Japan)
Top plate: Metal
Bottom plate: Metal
Battery cover: Threaded
Assembled in: Unknown
Location of manufacturing/assembling information: Unknown
Year of original purchase (if you know): unknown (a friend bought at a yard sale long ago, and I'm buying it from him)
P.S.: doing my research these days I read somewhere (Wikipedia?) that the 50mm Pentax-A lens was introduced in 1983. This camera has the previous lens, the 50mm Pentax-M (as can be seen by the aperture ring below, lacking the A-position and little button after the 22). Assuming the lens on this camera is the original one that was sold with it (reasonable), then this camera should be from 1983 or earlier. That's the best guess I could arrive at so far for its age.
PENTAX K10D  Photo
PENTAX K10D  Photo
PENTAX K10D  Photo
06-03-2009, 09:53 PM   #103
Model: K1000
Serial number:8225783
Asahi Opt. Co. engraved on back side of top cover: Yes (no 'Japan')
Top plate: Metal
Bottom plate: Metal
Manufactured/assembled in: Hong Kong(?)
Location of manufacturing/assembling information: Bottom plate sticker
06-03-2009, 09:55 PM   #104
Model: K1000
Serial number: 7282078
Top plate: Metal
Bottom plate: Metal
06-05-2009, 10:53 AM   #105
Model: K1000
Serial number: 7754933
Top plate: Metal
Bottom plate: Metal
Weight (without batteries and body cap) (if you know): brick-like
Closed Thread
asahi, bottom, data, database, information, k1000, metal, plastic, plate, screen
Lens Serial Number Database Ole Pentax SLR Lens Discussion 57 04-17-2016 09:58 AM
DA* 16-50mm Serial Number Database. Buddha Jones Pentax SLR Lens Discussion 528 06-13-2012 01:11 AM
Serial Number Database royal07 Pentax SLR Lens Discussion 1 10-15-2010 05:04 PM
Serial Number dating John Araki Photographic Technique 2 08-28-2008 11:13 PM
All times are GMT -7. The time now is 11:56 AM. | See also: NikonForums.com, part of our network of photo forums!
