02-23-2009, 09:57 PM   #16
It's the midtones, man...that pic does, a bit - no doubt the DD-X helps (with HC-110, you can kiss anything that might vaguely be considered a shadow).
It certainly looks better than my efforts. I think I'll dig out my Microphen for the next roll of HP5+.
02-23-2009, 10:03 PM   #17
Yeah, it definitely has a heavy feel to it, I understand that nagging feeling. Ilford's just plentiful and found in many flavours where I live, and it's what I started shooting when I went back to film.
Maybe I should take a break and try some fuji or kodak.
02-24-2009, 12:54 AM   #18
jgredline's Avatar
Simply beautiful!!!!!
02-24-2009, 06:31 AM   #19
Lowell Goudge's Avatar
QuoteOriginally posted by CSoars Quote
It's a shame my MX's meter doesn't go past 1600, though I know it's not a hardship to extrapolate. But my LX goes higher.... hrm. Might need to bring along an ND filter though.
I don't understand the comment about your MX meter. My KX goes to 6400! but aside from that, I'm not sure you need a ND filter, afterall why block out the moonlight My shots were lit by a single bulb hung on the mast of the boat.
02-24-2009, 08:38 AM   #20
I mean the ISO dial stops at 1600, which is what the meter is coupled to. Unlike the LX with it's LED 'match needle' style readout, the MX only has (+1, +1/2 ,0 -1/2 ,-1) Lights in the viewfinder. So even with the ISO dial at 1600 and a mental -1 stop added, a 3200 rated scene would simply be a red LED, with no way of knowing how MANY stops underexposed unless I twiddle the shutter dial to a slow enough speed to read green, then dial it up a speed. (or close down a stop)
Add to that the necessity to usually underexpose for the center weighted meter, and I'd be fiddling around with the dial to do the mental math; may as well shoot blind with a guesstimate from the sunny 16 cheat sheet. (1/30th @ f/4 @ ISO 400 = night streets and indoor stages)
BTW my LX ISO dial stops @ 3200, though the meter is more than capable.
02-24-2009, 09:14 AM   #21
i guess I am surprised by this, simply because the MX was supposed to be the M series replacement for the KX. I would have thought this is a limiting factor since pushing B&W has been around longer than SLRs.
02-24-2009, 09:20 AM   #22
Maybe it has something to do with the MX using GPD cells, where the KX uses a silicon photo diode. Odd, isn't it. They both have rubberized silk shutters, hey?
iso
Ilford Delta 3200 - shoot at 800-1600, develop at 1600? dugrant153 Film Processing, Scanning, and Darkroom 15 11-08-2010 02:27 AM
People 400 ISO pushed to 1600 icywarm Post Your Photos! 3 07-16-2010 10:31 PM
Ilford HP5 400 temperature bnishanth Pentax Film SLR Discussion 8 03-02-2009 03:50 PM
Ilford HP5 shots Gooshin Pentax Film SLR Discussion 9 01-17-2009 01:50 PM
Shot some Ilford HP5 Plus (2 sample shots) CSoars Pentax Film SLR Discussion 15 01-12-2009 10:24 AM
All times are GMT -7. The time now is 01:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
