Originally posted by John Poirier I'll steer this a bit toward the orginal topic...
Why the continuing popularity of the MX? It's a little jewel that continues to be capable of making good pictures. It has the essential character of a fine mechanical instrument, which means that there is pleasure in using it. I have mine in a kit with a KX, (another mechanical beauty) and several prime lenses. The MX is loaded with HP5 and used hand-held (with winder). The KX is loaded with FP4 and is used mainly on a tripod, usually with its very convenient MLU.
That's kind of how I work, MX handheld with 400-1600 speed for available light, LX (with MLU & IDM meter) is for slower colour and tripod stuff. Not always, but it seems to work this way.
Originally posted by ChrisPlatt The nylon screw catch for the Winder MX battery compartment is a really poor design - so unlike Pentax!
On mine partially depressing the winder release wouldn't activate the meter, a common problem. Eric fixed that.
The Winder MX does help the handling a bit, but the increased weight kind of defeats the purpose of the miniature camera.
I have thought about attaching the winder without batteries, but the vertical grip just gets in the way of the body release...
Chris
My Winder doesn't activate the meter either, I have to cock the lever to the stand off position and half-depress the body shutter. I'm thinking I may have a loose connection in there from my partial disassembly to get the batteries in.
Maybe when I get that SC-21 screen from Chris, I'll drop the SA-21 into the MX and get erik to calibrate the meter and check the winder; he did a wonderful job getting my LX back up and running.
Also, my MX's top plate and prism is pristine, whereas my LX's FA-1 finder is quite dinged up and dented (jest the exterior metal).
