Originally posted by stevebrot Wrong side indeed! In all likelihood the lever was damaged before you got the camera and this is not the fault of the Zenitar.
This is very possible. I got it from an auction and the owner claimed to have taken a couple of rolls with it, and it was pictured with another lens than it came with, so obviously it has seen lens changes. I don't know.
Originally posted by stevebrot How did the Zen fair? Hopefully it was not damaged beyond repair.
I don't think so. It seems okay but the aperture communication pin is bent, about as much as the one on the camera. I'm going to be very afraid to ever mount this lens on the ME ever again, though, so the Zenitar is probably a digital-only lens from now on. Which sucks, as it's so much more useful on film.
Originally posted by stevebrot This damage to the body is repairable, though I would suggest a good shop with access to another body for parts. The lever attaches to a sliding ring with an attached resistance strip. A spring-loaded contact slides on the resistance strip to make the circuit for the meter. Move the ring and the metered shutter speed changes. Since alignment here is pretty critical (as you just learned), the best solution is to replace rather than just bend the damaged parts. I suspect that the same part is common to all M series bodies and maybe the K series bodies as well.
Too late.
I'm not the kind of guy who sends things off for repair, and besides, this body is worth so little that it's bound to not be worth it. It wasn't in great condition to begin with. I removed the mount and bent the pin back (note to self: steel is VERY strong!) Looks straight to me. I will check the metering against my K100D to see how accurate it is, though.
I have another problem now though; I removed the mount, which seemed simple enough, and when I'm trying to put it back together, I can't get the lens release button to be springy. It's really hard to explain, but as soon as I start screwing the mount back, the lens release button is all stiff. The spring is there underneath it and I don't see that I've done anything differently from how it looked when I took it apart. Huh.
