Show Printable Version 43138 Likes Search this Thread
11-22-2017, 07:18 PM - 4 Likes   #16201
K2, K24 2.8 & Porta 400
11-22-2017, 11:00 PM   #16202
Jonathan Mac's Avatar
QuoteOriginally posted by longbow Quote
K2, K24 f2.8 & Porta 400 - 2 photo merged Panorama
I sometimes merge digital photos either as panoramas or for Brenizer-effect photos, but I've never done it with film ones due to the differences in scanning each frame (exposure, colour balance). Then it hit me the other day - scan the shots in the same file/image to get identical scanner settings, then split them into different files, then merge as normal. I don't know why I didn't think of it sooner.
Is that what you did here?
11-23-2017, 03:12 AM - 3 Likes   #16203
dsmithhfx's Avatar
Acros
11-23-2017, 06:10 AM - 3 Likes   #16204
baro-nite's Avatar
QuoteOriginally posted by Jonathan Mac Quote
Like this!
Pentax 645n
FA 75
11-23-2017, 07:20 AM   #16205
I sometimes merge digital photos either as panoramas or for Brenizer-effect photos, but I've never done it with film ones due to the differences in scanning each frame (exposure, colour balance). Then it hit me the other day - scan the shots in the same file/image to get identical scanner settings, then split them into different files, then merge as normal. I don't know why I didn't think of it sooner. Is that what you did here?
Just did the same as I do with digital, set up 2 photos in the field, note the frame # in a notebook. After scanning the negatives (I use a Epson V800) import them into Lightroom 6 and merge them there. Seems with film the alignment needs to be more precise, I had setup for 3 pano's on this roll, this photo was the only one that could be merged. Hope that helps.
11-23-2017, 08:50 AM   #16206
cooltouch's Avatar
Guys, is "merging" something that requires Lightroom to do? Can you do this in Photoshop or Paint Shop Pro? I have access to a copy of Lightroom but I never use it because I don't quite understand it yet.
11-23-2017, 10:11 AM - 1 Like   #16207
dsmithhfx's Avatar
QuoteOriginally posted by cooltouch Quote
You can do it in photoshop manually, a somewhat laborious process, by adding all the images as separate layers with narrow gradient masks for the overlaps, then use rotation and perspective distortion on each layer to match up as best you can. If you used a tripod and level, this is actually pretty easy, just remember to build in adequate lateral overlaps in your framing. The overlaps will be a bit blurry compared to other parts of the pano, but if you build it at hi-res and scale down, that is less noticeable.
Maybe this has been automated since last I did it ~20-years ago.
11-23-2017, 12:46 PM - 1 Like   #16208
A low light shot using the K 85 @ f1.8, 1/30 sec with the K2, Porta 400
Rosie, our Goffin's cockatoo, resting on my wife's shoulder....a rare moment of her actually sitting still.
11-23-2017, 11:00 PM - 4 Likes   #16209
g026r's Avatar
A shot that didn't quite turn out. Managed to hold the camera steady & didn't back focus too badly — both things I habitually do with this camera — but didn't get quite enough DoF. Possibly a little bit further back to get some more DoF would have been advised.
(You can also spot where the film isn't held entirely flat. It's virtually impossible for me to get a sharp image along the bottom middle of the frame with this camera, even in shots where the corners are otherwise acceptable. )
This is definitely not a lens that was designed for colour film, but it's fun to run a roll through from time to time.
K.W. Pilot Super.
K.W. Anastigmat 75mm f3.5.
Kodak Porta 160.
11-24-2017, 03:15 AM   #16210
dsmithhfx's Avatar
HP5+
11-24-2017, 01:26 PM - 4 Likes   #16211
gofour3's Avatar
These shots of the Sydney Harbour Bridge are from 2007. (The second was taken from inside the Opera House)
KX & FA 28-105mm F4.5-5.6, shooting Kodak Elitechrome 100.
Phil.
11-24-2017, 01:56 PM - 5 Likes   #16212
You can do it with Photoshop or Photoshop Elements, using the Photomerge tool.
---------- Post added 11-24-2017 at 01:19 PM ----------
Pentax Z-1p
SMC Pentax-F 28/2.8
Kodak Portra 400
Nikon Coolscan V ED
11-24-2017, 02:48 PM   #16213
Jacquot's Avatar
Great shot of the ladies.
11-25-2017, 12:31 AM - 1 Like   #16214
cooltouch's Avatar
Great shots Phil. Elitechrome was great stuff. Hey, I'm thinking this is probably what Kodak will be bringing back to the market soon . . . weren't they forecasting November? So where is it?
Can't wait to get some more of that film.
11-25-2017, 06:22 AM - 2 Likes   #16215
dsmithhfx's Avatar
architecture, details, ektar, exposure, film, goats, grandma, hood, kodachrome, kodak, lab, legs, lens, lunch, lx, mx, pentax, phil, photos, post, q7, roll, sarajevo, scans, shot, shots, steve, thanks, tokina, velvia
K20D test shots at Lets Go Digital schufosi777 Pentax News and Rumors 6 04-20-2013 11:31 AM
Macro Cool Macro shots derajjjg Post Your Photos! 2 12-27-2009 09:36 PM
Lets see your Moon and Mars shots Igilligan Post Your Photos! 9 12-05-2009 08:55 AM
Way cool bat shots and General Talk 7 10-01-2009 02:54 AM
Cool Shots & Info Fl_Gulfer Post Your Photos! 0 12-10-2007 11:44 AM
All times are GMT -7. The time now is 12:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
