Originally posted by aurele So far, the SuperA has been a work horse for me. It work with all lenses, whether or not it have an aperture ring.
An issue can occure however : half pressing the shutter button can not start the metering in some case (short raison : some grease preventing the contact to happen).
Right, I forgot about that. I had the meter switch replaced on my Super A after a while due to that malfunction.
Originally posted by aurele The other body is the MZ-5n. Very simple, quite efficient. It can use a grip that allow the use of standard AA batterie. Lightweight. Supercheap and widely available. and so on.
An issue can occure : sticky shutter / sticky mirror as Wkraus explained it.
To avoid any misunderstanding: the recurrent issue with the MZ-5/MZ-5n is that the mirror drive mechanism breaks for good (or is it for bad?). The camera is then beyond repair considering its value. The sticky mirror that the LX is famous for is different and less fatal: a rubber piece on which the mirror rests becomes sticky. You can use the MLU function to get the mirror unstuck before shooting, but it's also a simple repair.
To bring this on topic: Here's a shot with my Super A and (probably) the smc Pentax-M 100mm f/2.8 with bounced flash on Agfachrome 200 RS slide film--a Berber bride in the Moroccan High Atlas mountains being dressed up (November 1985).
