Originally posted by LesDMess I was using the EOS3+70-200L+2XTC for that wishing I had a 500mm+. I learned that shooting airshows and such requires some serious lenses as I tried all the cheaper alternatives.
That F8F was the Rare Bear and it went on to win that year and the next if I remember correctly. This one on Velvia 100F using the same rig.
I have gotten rid of all my EOS gear in favor of the manual world for sometime now.
Oh, of course, Rare Bear, probably the most famous F8F of all. I don't think I've ever seen it in person at an at airshow, although I've seen other F8F racers, despite the many dozens I attended back in the 80s and 90s in California. I have quite a few photos of one of Rare Bear's chief competitors, Strega, owned by "Tiger" Bill Destefani. But none up at my website. I used to live in Bakersfield, which is Destefani's hometown, so I'd see Strega and his other P-51, Mangia Pane (Eats Bread), flying around, plus they made most of the local and regional airshows. He had them hangered out at Bakersfield Municipal Airport for a while.
As far as lenses go, I've found that it often depends on the venue and whether or not I was able to finagle a press pass. At the Warbirds show at Minter Field, I could get a press pass and they'd let us out on disused portions of the runway sections, so we were away from all the show minions. Usually, though, that sort of access just costs a lot more to be able to sit in a special area that gives you few advantages over being stuck in the middle of the hoi poloi, so I never paid the extra and managed to get good photos nonetheless.
At the Minter Field shows, because we were out there a ways, I could make good use of a 500mm, but at most other shows, 300mm was more than enough. Here at the Houston event, I've found that, in some cases, 400mm is too much. 300mm is a good middle ground for here. A good 300mm zoom is often the best way to go because then I can zoom in some if 300mm is becoming too much.
My best lens right now for airshows is my Tamron 300mm f/2.8 LDIF. I have a couple of good zooms I like to use, as well, one AF, one MF. And I also like to carry wide angles for the static displays.
Steve, thanks for sharing! Yesterday I found a box with a bunch of Kodak slide boxes in it. I need to go through it and see if this is where my last of the Kodachrome slides are. If so, I'll fish out number 36 (or 37 or 38) and post it here.
