09-02-2015, 04:19 PM - 2 Likes   #11851
On the same roll of Fuji 100 and Pentax LX
Larger version -> Walk around waterfall in SC
09-03-2015, 07:42 AM   #11852
QuoteOriginally posted by Swift1 Quote
Here's a possibly better example.
The upper frame is a 6x7 Velvia RVP slide, shot with a 200mm lens. The lower image is 35mm Kodachrome slide, shot with a 90mm lens.
When both are viewed at the same magnification (from original), the apparent detail and tonal quality is about the same.
Nice shots, though to my eye the tonal quality is superior on the 120. You're making it hard for me to sell my medium format equipment, sir.
09-03-2015, 12:44 PM   #11853
Swift1's Avatar
QuoteOriginally posted by Archimedes the Dog Quote
Why on Earth would you sell your medium format equipment?
09-03-2015, 12:57 PM   #11854
To buy other medium format equipment!
And more lights.
09-03-2015, 12:59 PM - 1 Like   #11855
Swift1's Avatar
And more lights.
I can relate to that reasoning
---------- Post added 09-03-2015 at 01:00 PM ----------
Zenza Bronica ETRSi
Zenzanon EII 75/2.8
Kodak Ektar 100
Epson V500
09-03-2015, 05:05 PM   #11856
Cuthbert's Avatar
My first shots in medium format have been disappointing...I used an old Super Ikonta III and most of the shots came overlapped and in any case the frame was irregular, plus out of 18 exposures I just got 9 (for 3 of them I assume I made an error in the exposure), so I couldn't make shots as good as Colton.
The lens is a Novar and the film XP2, I was thinking about getting another folder like the Iskra but I'm not totally sure at this point.
09-03-2015, 05:25 PM - 1 Like   #11857
chickentender's Avatar
Velviating along the Columbia River historic route roads...
MZ-3 / 31mm Ltd / Velvia 100F
09-03-2015, 06:04 PM   #11858
QuoteOriginally posted by Cuthbert Quote
You did better than me. My first time out with the Ikonta C 6x9, I didn't advance the film far enough. Just till I saw the red dot, and forgot to look in the window. The result was twelve or more images all over lapping. They were mostly shots in a forest so it looks like one long negative with nothing but trees.
09-03-2015, 06:10 PM - 1 Like   #11859
Swift1's Avatar
The Super Ikonta has a frame spacing issue due (I think) to it being designed for older style spools that had a slightly narrower thicker shaft.
My friend has a Super Ikonta IV and he has an easy trick that basically solves this problem.
Take a yellow Post-It, cut it the width of the film, then when you're loading film, right after you get the paper leader started on the take-up spool, stick the Post-It onto the paper right at the spool, then wind till the Start arrow lines up, close the back, and proceed as normal.
The Super Ikonta III and IV are great cameras, but the film advance/transport is touchy and can be problematic, so make sure you do things in the correct sequence, and don't try to force anything.
---------- Post added 09-03-2015 at 06:49 PM ----------
Rolleiflex 2.8C
Carl Zeiss Planar 80/2.8
Kodak New Portra 400
Epson V500
09-03-2015, 06:50 PM - 1 Like   #11860
One more from our recent road trip, but with the Franka... Just above the Columbia Gorge at Davies Pass in Washington.
Franka Solida III / Radionar 80 2.8 / Provia 100F
09-03-2015, 06:53 PM   #11861
Swift1's Avatar
QuoteOriginally posted by chickentender Quote
Nice work.
I like this composition a lot.
09-03-2015, 06:57 PM   #11862
Rolleiflex 2.8C
Epson V500
I love this shot. Mucho.
---------- Post added 09-03-15 at 06:58 PM ----------
Nice work.
Gracias. I *just* missed the edge of the sign... Darn parallax. I'm a rangefinder newbie.
09-03-2015, 08:42 PM - 1 Like   #11863
I like it, it anchors the shot.
09-03-2015, 09:38 PM   #11864
Some Portra 400 frames I shot in Reykjavik, Iceland.
M2 + 35mm Color Skopar
09-03-2015, 09:43 PM - 1 Like   #11865
Swift1's Avatar
That gives it a slight Eggleston quirkiness that works
---------- Post added 09-03-2015 at 09:45 PM ----------
QuoteOriginally posted by nickthetasmaniac Quote
Love the colors you get. Great job scanning.
architecture, details, ektar, exposure, film, goats, grandma, hood, kodachrome, kodak, lab, legs, lens, lunch, lx, mx, pentax, phil, photos, post, q7, roll, sarajevo, scans, shot, shots, steve, thanks, tokina, velvia
K20D test shots at Lets Go Digital schufosi777 Pentax News and Rumors 6 04-20-2013 11:31 AM
Macro Cool Macro shots derajjjg Post Your Photos! 2 12-27-2009 09:36 PM
Lets see your Moon and Mars shots Igilligan Post Your Photos! 9 12-05-2009 08:55 AM
Way cool bat shots and General Talk 7 10-01-2009 02:54 AM
Cool Shots & Info Fl_Gulfer Post Your Photos! 0 12-10-2007 11:44 AM
All times are GMT -7. The time now is 10:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
