Originally posted by stevebrot Scratched negatives. Check the film path in the camera for rough spots and if you squeegee your negatives, stop. My guess is this happened after the film was taken out of the camera.
I also stopped using the squeeze squeegie thing. It was scratching my negs and I refuse to use it any longer.
I also stopped doing inversions with my paterson tanks, that inversion process was creating lines of dirty haze on the negatives where the levels matched up from normal to invert. I use the swizzle stick to rotate for agitation.
When i start my process I dip the ends of two kitchen sponges in water, and set them aside to wick the moisture up. When I am ready to wipe my negs for drying, I use the now, almost dry sponges to gently squeegie the water down the strip. I am thinking about using chamois instead.
