Originally posted by gofour3 Cool, like the first one's bokeh!
Phil.
---------- Post added 07-24-16 at 02:37 PM ----------
A sample shot from my second roll of 1997 expired AgfaChrome RS1000.This one was taken at ISO 160, looks like I still have to go down a bit, maybe to even 50 ISO.
Still I'm having fun mucking with the old slide film and my bazooka zoom. (LX & K85-210/3.5)
Phil.
I like it, it has a sort of "lomo" quality.
I also resurrected something from a galaxy far, far away, namely the T80 I bought some time ago and didn't bother testing it so far.
So, this is also a mini-review of the relic from the 80s, for those who don't know this is the first AF camera from Canon, more or less equivalent to the Pentax ME-X.
Like many Canons of the era it suffers to super-automation, you can't use it manually but there are five programs, from the small guide that came with it, it appears that Canon wanted to make a SLR easy to be used for people who didn't bother learning proper photography, F stop, EV and shutter speeds but wanted to get "pro" pics, so if you want to shoot open wide there is a program (shallow DOF), if you want a deeper DOF there is the relative program, if you want to shoot fast objects giving the impression of speed (Cooltouch's pics of racing cars) there is the flowing mode where you can select few shutter speeds. If you want to use fast shutter speeds there is the freeze program, for the rest there is the standard program. In the booklet everything is explained very well with simple language.
I have the two zooms, the 35-70 and the 70-200, they are optically like the standard FD lenses, that means consumer's zooms from the 80s so not so great, you can shoot manually, with AF or locking the subject. Sometimes the autofocus fails dramatically, but the camera is equipped with the L screen (that I also have in my F1N, it's quite rare) so manual focus is possible. The T80 is noisy, it beeps when the focus is locked, but I somewhat like this camera, because it's smaller and the blue plastic body feels better than for instance the T90.
Few shooting samples:
The macro capability of the 35-70 is laughable.
Also not much flare resistant.
This one has been taken at 70mm, shallow mode.
The barrel distortion is evident.
70-200 shot at 200mm, shallow mode. The separation is minimal as you can see...the Sonnar 200mm f2.8 is another lens.
Nevertheless the AF when it works makes a good work, 200mm shallow mode.
Pincushion distortion (moderate) for the long lens.
Probably the best shot of the series for me.
1/30 flowing mode, not enough to see the flow of the water.
Difference between 70mm shallow and 35mm program mode.
Boring architecture at about 45mm with a circular polarizing filter, that is difficult to use as the lens goes forward and backward.
In short interesting toy, nice built camera with typical industrial design of the mid 80s, and it also takes pictures! The film used was Fuji Superia 200.
Here with another example of design of the same era, I hope I didn't bore you to death with this post.
