03-10-2009, 07:48 AM   #1
SuperAkuma's Avatar
Any sample of a 400 film pushed to 1600? BW only
Do anyone have any shot with a black and white film that was pushed 2 stop from 400 to 1600? I just want to see how much film grain it will have.
I also would like to see it pushed from 400 to 800 or even 3200.
Since I just started film, I don't know much about it. I have one question on it. Can you tell a difference between a 400 film pushed to 800 vs a film that is 800 speed native? Or a 400 pushed to 1600 vs a 1600 speed native?
Thanks for anyone who can give me some examples or answer the question.
03-10-2009, 08:15 AM   #2
I posted a thread a couple weeks back. One thing with B&W, you're unlikely to find 'native' 200 or 800 speed films, and I think most anything 'fast' made by kodak or ilford (tmax/delta 3200) is of a different emulsion that usually has finer grain than 'traditional' ones such as Tri-X, so it's hard to compare.
increased grain isn't the only consideration, you'll notice the tonal range is compressed, so you'll hit pure white and black much sooner; the film doesn't support as much contrast when pushed.
This is HP5+ @ 1600
https://www.pentaxforums.com/forums/pentax-film-slr-discussion/52022-ilford-h...ed-1600-a.html
I've also shot some Delta 3200 (rated for 1600), and it's quite nice grain wise, but low contrast; you need to develop it longer than the box says.
03-10-2009, 08:21 AM   #3
Gooshin's Avatar
here is 400 pushed to 1000
03-10-2009, 08:50 AM   #4
Ask, and ye shall receive, Akuma:
Deltax 400, +2, D-76
Tri-X, +2, D-76
Ask me if I've got any pushed three stops...
03-11-2009, 08:56 PM   #5
SuperAkuma's Avatar
Thanks for the sample photo. Do you have any pushed 3 stops? You asked me to ask you.
03-11-2009, 09:02 PM   #6
heard that Neopan 1600 works well
03-11-2009, 10:35 PM   #7
jgredline's Avatar
Is the pushing done in PP or in camera settings?
03-11-2009, 11:08 PM   #8
Venturi's Avatar
QuoteOriginally posted by jgredline Quote
Both, sort of.
When you push film you set the camera 1 or 2 stops, typically, above its rated ISO. So if you have a roll of ISO400 film you would set the camera to either 400 for a 1 stop push, or 800 for a 2 stop push. You are actually underexposing the film. SHOOT THE ENTIRE ROLL THIS WAY.
Then during the developing stage of processing the film you, or a competent lab, leave the film in the developer for extended time to compensate for the underexposure.
Pull processing (shooting at a lower ISO setting than the film's rating) is just the opposite - less time given in the developer. There's not much call for pull processing though because you don't have nearly as much latitude in dynamic range overexposing film as underexposing. Maybe if you were doing a high-key shoot it would be appropriate???
03-12-2009, 02:23 AM   #9
QuoteOriginally posted by Venturi Quote
Tri-X is the notable exception to this - the developing times for ISO 800 are exactly the same as those for ISO 400 (altough Venturi is just providing a general example).
It's fairly easy to do, push processing, and not really harder than normal processing, although it's a bit more sensitive to time and temperature fluctuations, as there's less latitude.
Sure, there are high-speed films out there - TMZ P3200, Delta 3200 and Neopan 1600, but all these (while still being high-speed), aren't really at their given box speed.
For example, TMZ 3200 is really around ISO 1250. You'll notice that on the boxes of all these films they'll call what you think is the "ISO" rating the "EI" (exposure index) rating, mean you're not shooting the film at its true speed.
Why do I mention this? Because while some people like using high-speed film for their work, often you'll get similar results if you just push 400 ISO film.
03-12-2009, 05:36 AM   #10
pasipasi's Avatar
Flickr is pretty good for finding examples from different lenses, films etc, and here is about 1400 pictures from the search 'tri-x pushed 1600'. Pretty good results pushed I think.
edit: forgot the link
03-12-2009, 06:49 AM   #11
Nachodog's Avatar
What's the general rule when it comes to extending developing times when pushing a film? Is it mostly trial and error? Is the time/ISO relationship linear?
03-12-2009, 06:50 AM   #12
Gooshin's Avatar
QuoteOriginally posted by Nachodog Quote
each film comes with a "data" sheet, that sheet will list instructions for push processing depending on set of chemicals used.
03-12-2009, 07:05 AM   #13
Venturi's Avatar
QuoteOriginally posted by lithos Quote
Tri-X is the notable exception to this - the developing times for ISO 800 are exactly the same as those for ISO 400.
I did not know that. Good info, thanks!
03-12-2009, 07:08 AM   #14
Venturi's Avatar
Re-reading my own words, I see I botched my numbers. Should have written....
"if you have a roll of ISO400 film you would set the camera to either 800 for a 1 stop push, or 1600 for a 2 stop push."
03-12-2009, 08:47 AM   #15
jgredline's Avatar
I figured that is what you meant. I do that all the time. Write , then proof read. Then get no biggie.
film, question, vs
People 400 ISO pushed to 1600 icywarm Post Your Photos! 3 07-16-2010 10:31 PM
Fuji Neopan 400 pushed to 1000 Gooshin Film SLRs and Compact Film Cameras 6 09-03-2009 01:08 PM
Can infrared film be pushed? SuperAkuma Film SLRs and Compact Film Cameras 2 04-22-2009 05:14 PM
Ilford HP5+: round 2, pushed to 1600. CSoars Film SLRs and Compact Film Cameras 21 02-24-2009 09:20 AM
400 kodak UC pushed 1 stop eccentricphotography Film SLRs and Compact Film Cameras 0 09-05-2008 09:53 PM
All times are GMT -7. The time now is 01:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
