03-14-2009, 02:18 PM   #1
SuperAkuma's Avatar
Pentax ZX-L won't take picture pointed up?
Today I did some shooting for my class. I've used the ZX-L for a while now and never had this problem before. For some reason today when I pointed the camera upward directly at the sky, it would not allow me to take a picture.
I though that it was because there was nothing to focus on so I moved to a spot where there was a lamp post. I tried it again, pointing all the way up, it still won't focus.
The lens that I am using is the Zenitar 16mm fisheye lens. I have no tried it with any other lens yet. But the camera works fine with the Zenitar in all the other shots.
Is there something that I am doing wrong?
03-14-2009, 02:38 PM   #2
did you try in manual focus? i.e. set the camera to manual focus mode. with manual focus lenses on AF mode, the camera works on catch focus
03-15-2009, 06:38 PM   #3
SuperAkuma's Avatar
QuoteOriginally posted by k100d Quote
Thanks that worked.
I wonder why it wasn't able to take the picture when I pointed up when it was on AF? You said that it needed to catch something to focus on, I did point at something, a lamp post but it still wouldn't fire.
Today I tried it again but with it on manual and it fired.
03-15-2009, 06:46 PM   #4
i think none of the film bodies until the *ist has cross sensor points. so sometimes if you focus on a vertical line, it won't be able to pick it up. if you're having trouble getting a lock on vertical lines, tilt the camera at a 45 degree angle and it should be able to lock.
stick to the center point focus too, that way you always know what it is trying to focus on.
camera, focus, lens, pentax zx-l, picture, zenitar, zx-l
Misc That K-x That I Won jct us101 Post Your Photos! 5 06-20-2010 09:48 PM
AF360FGZ vs Metz 48 AF-1 in wireless mode, Pentax won skid2964 Flashes, Lighting, and Studio 10 01-24-2010 01:09 PM
Never Guess What I Won At the Pentax K-7 Road Tour -- Portland stevebrot Photographic Technique 17 08-18-2009 09:24 AM
Are people required to be in a picture to make it a good picture? BPT Photographic Technique 46 07-07-2008 05:44 PM
I won! rfortson Post Your Photos! 20 02-23-2007 06:18 PM
All times are GMT -7. The time now is 03:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
