03-15-2009, 10:17 AM   #1
Newbie with ZX-5 issue..help anyone ?
I have a ZX-5 that I bought last year on craigslist, loaded film into it, shot 2 rolls and put the camera away. Finally got around to getting the film developed, and the pictures are GREAT !...Except for one thing...every picture has the top 1/3 and the bottom 1/3 blacked out.
Somebody in another forum suggested that the light seals were bad, but I kind of do not agree with that analogy...the part of the pictures that are not obscured are excellent quality.
Anyone come across this sort of thing ?
Expensive repair ?
Can I even get parts to repair it ???
Any suggestions will be greatly appreciated.
Thanks.
03-15-2009, 10:29 AM   #2
Ole
Ole's Avatar
Does that model have a panorama setting? What you describe is exactly what the panorama setting would do, mask the negative to panorama format.
03-15-2009, 10:30 AM   #3
Ole
Ole's Avatar
I just checked the manual. The camera does have a panorama setting, engaged with a small lever next to the view finder.
03-15-2009, 10:36 AM   #4
There does not seem to be a panorama setting. I have all the setting in the "auto" mode to try and get a baseline for my limited skills. The blacked out area's are just a little skewed from being horizontal...I'd say by about 10 degrees.. I had also switched lenses throughout the 2 rolls of film.
The pictures are not proportional to panorama, ie: a human body shot shows just that, the head and legs are cut off...LOL
03-15-2009, 10:38 AM   #5
Thanks for pointing that out...yes it does have that feature, and it is set in the normal position, not on the "p".
03-15-2009, 10:38 AM   #6
Ole
Ole's Avatar
The panorama switch is on the back of the camera, to the right of the viewfinder. What you describe sounds as if the panorama blinds are askew.
Perhaps the switch doesn't work and the blinds are always engaged? It should be easy to see with the lens off, or the back open (I don't know on which side of the shutter the blinds are located).
03-15-2009, 10:42 AM   #7
Thanks so much for your input Ole, I think that could be the culprit.
Can I fix it though ?
03-15-2009, 10:44 AM   #8
One other question, if I put the panorama selector in th "P" position, will the pictures only show up on 1/3 of the print ?
03-15-2009, 10:46 AM   #9
Ole
Ole's Avatar
QuoteOriginally posted by ryderhard Quote
I don't know if it is something you can fix it yourself. A repair shop could fix it, I'd assume.
Several on this forum, my self included, use Eric - he does an excellent job:
Home
03-15-2009, 10:49 AM   #10
Ole
Ole's Avatar
It depends on the photofinisher how they do this. I have had panorama shots done only once, they came back in a format like 4 by 10 inches or so (I don't remember the ratio) rather than the usual 4 by 6.
03-15-2009, 10:50 AM   #11
Well I just took the lens off, and cycled the panorama selector a few times...it seemed to be sticky, and you can see the shields moving up and down in the mirrors. I bumped the selector 6 or so times and now it seems to be smooth !!!
YOU DA MAN OLE !!!!!!!!!
03-15-2009, 10:57 AM   #12
Ole
Ole's Avatar
Happy to hear that it worked out!
03-15-2009, 11:02 AM   #13
Ole
Ole's Avatar
What you just wrote prompted this thought:
There must be two sets of shields, one set in front of the ground glass (that's what you see in the mirror), and one set in front of the shutter (that's what masks the picture). If the shutter can be fired in the 'B' setting or long exposure setting with the back open and no film you shout be able to see the latter set of shields. Or you can gently lift the mirror up and take a look.
03-15-2009, 11:10 AM   #14
Well I think I have it sorted out. The camera has film in it now, so I really do not want to open it up.
I hope that using the auto settings tonight will give me some good shots of the Space Shuttle launch tonight. I'll be using a Promaster 70-300 lens, and 400 film.
Fingers are crossed...
03-15-2009, 11:25 PM   #15
titrisol's Avatar
Location: In the most populated state... state of denial
That was the idea, and for a while they did it like a Panorama and you got 4x10 pictures which were pretty cool.
Then it was abandoned and now you get the pictures with ugly black lines.
film, pictures, repair, zx-5
Vivitar MC Tele Converter 2X PK-A/R-PK issue...or no issue? WiseOx Pentax SLR Lens Discussion 5 06-11-2014 01:14 PM
Possible Kx Issue? UnknownVT Pentax DSLR Discussion 21 11-29-2009 06:46 PM
A printer issue, or a processing issue... FHPhotographer Digital Processing, Software, and Printing 0 10-03-2008 12:13 PM
Help with possible 50 1.7 A issue dstoepfel Pentax SLR Lens Discussion 12 04-28-2007 01:56 AM
All times are GMT -7. The time now is 03:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
