04-15-2009, 09:55 AM   #1
ismaelg's Avatar
Problem with MV1 shutter curtain
Hello,
My old MV1 has develop a problem. The shutter curtain does not close completely. It stays partially open. If I gently move it down it closes and the mirror comes back down and the rewinder lever lock is released. Everything else seems to be working just fine.
I know I can send it for repair, but I want to see if there is anything I can do. I'm not sure I want to spend $100 in fixing a camera that is rarely used. This camera is my backup for my trusty K1000, which is now the backup for the K100D.
Here is a picture after pressing the shutter release button.
Also, when it is coming up with the rewinder, I see a little slit between both curtains. Not sure but I think they should overlap a bit. If I rewind very slowly then it seems to be overlapping ok.
Any suggestion? Any recommended locations to send it?
Thanks,
04-15-2009, 11:33 AM   #2
monochrome's Avatar
DK enough to make a recommendation. We have a Camera Repair and Maintenance Links section. You will find Pentax Camera Service - Eric Hendrickson. He wille evaluate the repair and estimate the cost (as wella s completely clean, lubricate and adjust the camera) for free and if you decline send it back to you for free. You are out only one-way postage to Tennessee.
Go to Home Page >> Links >> Camera Repair and Maintenance
04-15-2009, 12:10 PM   #3
ismaelg's Avatar
Thanks!
Great resource. I'll check it out.
Thanks,
backup, camera, curtain, mv1, rewinder, shutter
K7 and Flash on trailing curtain problem mymage Flashes, Lighting, and Studio 6 08-15-2010 03:17 AM
Sticky Shutter Curtain! Any Suggestions? builttospill Pentax Film SLR Discussion 14 08-11-2010 08:29 AM
Trailing curtain sync problem? hoanpham Troubleshooting and Beginner Help 3 11-20-2009 05:18 PM
ME Super - shutter curtain stuck paolojackson Pentax Film SLR Discussion 4 09-20-2009 01:01 PM
Max shutter speed halved in rear curtain. Deni Photographic Technique 9 05-12-2008 04:35 AM
All times are GMT -7. The time now is 12:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
