05-10-2009, 07:29 PM   #1
geauxpez's Avatar
Need Spotmatic Clarification - edited
Quick question: What is the difference between a Spotmatic designated on the front as a "Spotmatic F" and one that is only designated near the rewind knob as a "SP F"? Are these both Spotmatic F's or is there a difference?
Thanks!
**Edit -- I have seen a couple of Spotmatics that just say Spotmatic on the front and have no model designator near the rewind knob. ???
05-11-2009, 05:41 AM   #2
I could be wrong, but I think all Spot Fs are labeled in both places. For example:
ASAHI PENTAX SPF
05-11-2009, 10:23 AM   #3
geauxpez's Avatar
Thanks Jerry. I have revised my question a bit -- how about for models that lack designators like this one?
05-11-2009, 11:37 AM   #4
QuoteOriginally posted by geauxpez Quote
Check with Seaain (Woof) as this might be an early model Spotmatic. I know that one model had the round O in Honeywell and another had the 0 more like this. But I'm not sure which was early and which was late. Seaain does have an early model so he should be able to tell.
CW
05-11-2009, 11:38 AM   #5
noblepa's Avatar
That's the way Honeywell did it
That is a Honeywell Pentax Spotmatic. Honeywell was the US importer. From 1952 (or thereabouts) until 1976, all Pentax cameras sold in the US were imported by Heiland, which became the Honeywell Photographic Division. Cameras of that era but labelled as Asahi (the manufacturer) are ones that were originally sold in the rest of the world. The original Spotmatic did not have the top engraved designation. If you find an Asahi Pentax Spotmatic of the same era, it WILL have SP engraved on the top.
Here's a link to a picture of an Asahi Spotmatic F. http://www.ne.jp/asahi/japan/manual-camera/sp1.htm. If you look carefully, you can see the SP engraved on top, next to the rewind knob.
The Spotmatic F was a different model. It had the additional cam on the Super-Multi-Coated or SMC Takumar, lenses to allow for open-aperture metering, whereas the original Spotmatic, whether labelled Honeywell or Asahi, did not and required the use of "stop down" metering.
I believe that, after the original Spotmatic, Honeywell conformed to the Asahi practice of engraving a model designation on top. I'm pretty sure that the Honeywell versions of the Spotmatic II, IIa and F, all had the top designation. Interstingly, the Honeywell versions of the Spotmatic predecessor models, such as the H1a and H3v (S1a and SV in Asahi dress), did have the designation on top, but nothing on the front.
BTW, the Spotmatic IIa was a US-only model. It had a flash sensor on the camera body that worked with the Honeywell Strobonar 772 and 882 flashes, which were made by Rollei, not Asahi. Consequently, you will never see an Asahi Pentax Spotmatic IIa.
There were three models that had the top designation, but no front engraving. There were the SP 500, SP 1000 and SL. Technically, none were properly called Spotmatics. All were virtually identical to the Spotmatic, with minor exceptions. The SP 500 had no 1/1000 second shutter speed or self-timer. The SP 1000 lacked the self-timer. The SL had a self-timer, but no light meter. I believe that all three were available in both the Asahi and Honeywell names.
05-11-2009, 02:15 PM   #6
geauxpez's Avatar
Thanks for the info. The one in question is not an HV or SV era camera -- I can tell that much. The seller (not a camera guy) told me that he was told that this particular camera was an F even though it had no model designator on the body. Given that he was selling it as an F, I will evaluate it when I get it and if it is not, then I should have recourse. If it's an F, this should be really nice following a CLA.
Thanks!
05-11-2009, 02:23 PM   #7
QuoteOriginally posted by noblepa Quote
Quite right... The eBay auction is for a Honeywell plain old Spotmatic, where there is nothing on the top plate except a Serial Number. For the Asahi plain old Spotmatic, they had SP on the top plate.
The Honeywell Spotmatic F had SP F on the top plate as well as Spotmatic F on the front.
There are some big difference between Spotmatic models. Best source of summary information is here.
Die Cast Pro - Spotmatic Family Traits
If we can help with individual IDs, please feel free.
woof!
05-11-2009, 04:20 PM   #8
Ira
Thanks!
YOU LUCKY B**TARD!
That's*a GREAT condition black for a great price! I really want a black body (got others), but any decent ones that have been coming up on eBay have been going for a HELL of a lot more than that!
05-11-2009, 05:00 PM   #9
geauxpez's Avatar
YOU LUCKY B**TARD!
Thanks -- that's really what I wanted. Should get along fine with my LX and black ME Super. I had a VERY used black Spottie SP last year and even though I parted with it for a good cause, I can't help but think that I could have bought a silver one to donate instead.
By "plain old Spotmatic", where would it fall in the pecking order? Pre SP?
05-11-2009, 08:01 PM   #10
monochrome's Avatar
Go Here and scroll down to SP. That should be your camera. It is not a SP-F - but for that price, SO WHAT!! Further down you will find Spotmatic F info and there is also a side-by-side feature comparison on the website.
For a high quality, dependable CLA, at a fair price, at no risk to you from a Forum-member recommended (well, members here use him) CLA, email Eric Hendrickson - Pentax Camera Service. Review his website for prices and what he does - you will be pleased. (Reviewed and linked in Pentax Forums External Links Here)
05-11-2009, 08:21 PM   #11
geauxpez's Avatar
Thanks for the tips Monochrome. Eric CLA'd the last Spotmatic I had and currently has my LX. He will get this one as well.
05-12-2009, 07:46 AM   #12
noblepa's Avatar
Honeywell Spotmatic same as Asahi SP
The "plain old Spotmatic" ***IS*** the SP. The US importer, Honeywell, did not engrave the SP on the top. In the rest of the world, Asahi did engrave SP on top. Other than that, the two are identical.
People tend to refer to the "plain old Spotmatic" only to differentiate it from the Spotmatic F, the SP II and so on. There were four models that clearly bore the name Spotmatic.
The SP500, SP 1000 and SL are often referred to as Spotmatics, but technically, they are not, even though they are, in many respects, identical to the Spottie.
The ES and ES II, were also not technically Spotmatics. There were simply the Pentax ES and Pentax ES II, although everyone knew that ES stood for "Electro Spotmatic", and they looked very much like the "plain old Spotmatic".
Here is a more or less chronological listing of Honeywell/Asahi equivalents
Honeywell = Asahi
H2 = S2
H1,H3 = S1,S3
H1a,H3v = S1,SV
Spotmatic = Spotmatic SP
SL = SL (no meter)
SP500,SP1000 = SP500,SP1000 (low cost models, no s/t, 55mm f2.0 lens)
Spotmatic II = Spotmatic II
Spotmatic IIa = n/a
ES = ES (slightly reworked Elector-Spotmatic)
Spotmatic F = Spotmatic F (open aperture metering)
n/a = Electro-Spotmatic (Japan only, I believe)
ES II = ES II
At about this time, Honeywell left the photographic business and Pentaxes were sold in the US under the Asahi name. There never was a Honeywell Pentax K-1000, for example.
Even today, when Pentax USA is a wholly-owned subsidiary of Pentax Japan, they continue to use different model names in the US. The newest Pentax, the K-2000 is known as the K-m in the rest of the world.
In the nineties, the ZX series in the US was the MZ series everywhere else.
05-12-2009, 07:52 AM   #13
noblepa's Avatar
Spotmatic name
BTW, the name Spotmatic came about because the prototype, shown at Photokina in 1960, had a spot meter. It was a CdS sensor on a little arm that would swing down in front of the film plane and flip up, out of the way during exposure. It must have been a mechanical nightmare.
By the time the camera was released for sale, in 1964, the spot meter had been replaced by an averaging meter system, based in the penta prism. However, the marketing types at Pentax must have liked the name, because that's what stuck even though it no longer had a spot meter.
05-12-2009, 10:03 AM   #14
geauxpez's Avatar
Wow -- ok -- great info. I have nothing against the SP or Honeywell variant. Good to know what I'll have. If I really want open aperture metering on a given day, I'll take a K-mount.
05-12-2009, 04:46 PM   #15
Ira
I just noticed something about your buy that I didn't read before. And something else that doesn't make sense:
He says there's a shutter problem, and that could be more than a CLA. Also, he shows a manual for a totally different camera.
front, knob, rewind, spotmatic
In need of some clarification on sealing and water danger CWyatt Pentax DSLR Discussion 6 02-26-2010 01:46 PM
I would like some clarification on commenting on prices WheresWaldo Site Suggestions and Help 1 07-05-2009 03:26 PM
Clarification on Raw Button Function AGW Troubleshooting and Beginner Help 5 02-12-2009 12:56 PM
Weekly Challenge - Rule Clarification atupdate Weekly Photo Challenges 25 03-24-2008 08:31 PM
compression and file formats, some clarification? Gooshin Digital Processing, Software, and Printing 12 02-24-2008 06:31 PM
All times are GMT -7. The time now is 10:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
