05-19-2009, 07:42 AM   #1
MZ-M Troubleshooting help
I recently got an MZ-M from a fellow member here on the forums and after having several rolls developed, I had a line running through most of my prints. I had a poke around the forums and found several threads pertaining to dirt and debris in the takeup spool (if that's the right word). I gave the internals the best cleaning I could (compressed air with a bit of poking with a brush, avoiding the shutter), but I don't know if I actually got the debris out.
What I did was I used an expired roll of film, shot a few frames, and then popped open the back, and examined the film under bright light. However, due to the emulsion still present on the film, I was unable to determine if I got rid of the culprit. My question is: Is there something around the house I can use to wash the emulsion off? I'm using some expired C-41 film that came with a camera I bought off of ebay to do my tests.
05-19-2009, 08:12 AM   #2
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
You might want to read this thread too. I had/have the same problem, but it's not camera related it's process related.
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/60658-cant-figu...re-coming.html
05-19-2009, 08:21 AM   #3
No, it's not like that; it's a line that runs down the strip of film. It also lines up very nicely with one of the rollers that guide the film into the takeup spool.
Plus, I had these two rolls developed at two different locations and the line came on both films, and behaved the exact same way.
05-19-2009, 08:24 AM   #4
titrisol's Avatar
Location: In the most populated state... state of denial
Is the line on the emulsion (matte) or on the base (shiny) side
EMULSION SIDE: with no film in use your finger to detect if any of the rollers is dirty.
If it is, clean it and it should be OK.
BASE SIDE: Do the same for the pressure-plate and clean it.
05-19-2009, 08:24 AM   #5
Ok, then check for burs on the spool. May be a nick in the plastic.
05-19-2009, 08:54 AM   #6
I've already worked out that the rollers are the cause, as I troubleshooted it that far, and gave the camera a thorough cleaning. My main question is: without taking the film to a lab and paying to have it deveoped, is there some household chemical I can use to simply wash off the emulsion exposing the clear plastic?
05-19-2009, 09:16 AM   #7
Slight update. Tried alcohol, didn't work. Tried peroxide, didn't work. Tried Mr. Clean, didn't work. Tried bleach, and what do you know, the film is cleaned off completely! In fact the plastic underneath is a clear plastic... Although, I don't know if that's from the bleach... I've got the film hanging out to dry, so I'll know in a few hours if I got rid of the culprit.
05-20-2009, 04:16 AM   #8
titrisol's Avatar
Fixer is better than bleach, since it keeps the emulsion and allows you to see sratches on the emulsion side
bleach just strips the emulsion away
05-20-2009, 09:01 AM   #9
So then, I need some C41 fixer then... It's be cheaper just to get the negs developed... Oh well, it was an interesting idea...
05-22-2009, 12:57 AM   #10
titrisol's Avatar
BW Fixer works as well, and no it is not cheaper to get your negs developed
prints is a different tune though
05-22-2009, 06:16 AM   #11
Hmm... Perhaps a trip to the local camera depot would be in order...
Still it was a neat little escapade. Nice to know that bleach will quickly destroy negatives...
Besides, I thought it (whatever it was that was leaving the line) was actually gouging the plastic that the emulsion is set upon as the scratch was quite significant.
Still thanks for the help!
debris, emulsion, film, forums, mz-m
Suggestion Troubleshooting section needed Jasvox Site Suggestions and Help 16 12-10-2010 07:03 PM
Need help troubleshooting Studio Lighting D4rknezz Photographic Technique 5 04-19-2010 09:51 AM
Troubleshooting cabled studio strobe... amateur6 Pentax Camera and Field Accessories 4 06-28-2009 12:57 PM
6x7 troubleshooting tips , please Dnabors Pentax Medium Format 2 05-07-2009 01:34 PM
MV troubleshooting little laker Pentax Film SLR Discussion 2 03-29-2007 09:05 PM
All times are GMT -7. The time now is 12:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
