06-13-2009, 08:26 AM   #1
eSFotos's Avatar
Heaviest Pentax Camera
Well, my ME Super is too small and light that camera shake is an issue.
Since I have a heaps of M42 lenses and M42->PK adapter I want to stay with Pentax. I also have a Spotmatic so K mount camera would be good but not necessary.
I am used to Nikkon F3 so I want something that heavy.
I am looking at MX or LX. Are they heavy and not vibrating when mirror kicks up?
06-13-2009, 08:42 AM   #2
Banned
QuoteOriginally posted by eSFotos Quote
I dont know what the F3's mirror movement is like. nor the LX's so I cant really compare. the MX's is certainly pronounced but I have never noticed it to cause unecessary vibrations.
ME super 440g
MX 495g
LX 570g
nikon F3 715g
Pentax has always been known for its small lightweight bodies. there isn't a single K mount body that equals the F3 in weight. I cant say for sure, but I highly doubt any of the screwmounts will either... except maybe the ES/ESII but I highly doubt it. the heaviest K mount camera is the K2DMD at 685g. but good luck finding one of those.
in fact, to equal the F3 you would have to buy a K20D
06-13-2009, 09:12 AM   #3
geauxpez's Avatar
Have you considered adding a motor drive to the ME Super even if it's just turned off? That would be an inexpensive solution that would probably also improve handling. You could always replace the batteries with lead ingots!
After shooting the LX a bit, I almost think that my Spotmatic has less mirror slap.
06-13-2009, 09:32 AM   #4
Wheatfield's Avatar
I've owned both F3 and LX. The LX is not as heavy as the F3, but the mirror damping is about on par.
All the Pentax cameras that I've used have problems in the 1/8-1/30 second range with mirror slap, the Super Program is the worst, the LX is the best (very little to no problems depending on the condition of the mirror mechanism).
06-13-2009, 09:47 AM   #5
Otis Memorial Pentaxian
...K mount camera would be good but not necessary.
I am used to Nikkon F3 so I want something that heavy...
My heaviest camera body is my Mamiya/Sekor 1000DTL. It is a real tank at 725gm and uses M42 lenses.
06-13-2009, 10:19 AM   #6
Hi, have you considered putting some dampening material on it ? The great thing about adding your own dampening mass is that you can put it where you want it.
I shoot mostly available light, so that means the flash hot shoe and bottom are available. You could also put some on the lens if you are careful.
Materials like lead and cast iron are both damping and massive. Materials like steel are massive, but offer little damping by themselves. Aluminum is neither. Rubber can be highly damping and moderate mass.
The ideal setup for damping is to have layers of high mass (steel for instance) separated by layers of something springy, like rubber. If the layers are not equal size / thickness, it is even better, as each layer will dampen a different frequency range.
Just some crazy ideas to throw into the mix.
06-13-2009, 11:50 AM   #7
monochrome's Avatar
Body Mass
I use a KX and a Spotmatic F for film and the mass is a side benefit for just this reason. The KX is 631g and has the mirror lock up feature (useful on a tripod).
I've always found the M cameras too small for my large hands
06-13-2009, 03:03 PM   #8
ftpaddict's Avatar
Since you didn't specify what format you were aiming for, might I recommend the Pentax 67? I am am pretty sure it beats all the other "scores" with room to spare.
06-13-2009, 03:22 PM   #9
QuoteOriginally posted by ftpaddict Quote
Read OP's post.
"... my ME Super is too small and light that camera shake is an issue... I have a heaps of M42 lenses and M42->PK adapter I want to stay with Pentax...
I am used to Nikkon F3 so I want something that heavy. I am looking at MX or LX. Are they heavy and not vibrating when mirror kicks up?"
06-13-2009, 05:23 PM   #10
eSFotos's Avatar
You guys rock.
Great recommendations.
I've never thought about adding weight to ME Super. MD would be ideal.
I will either get the MD for MES or get LX or get both - good reason to get another cam.
06-13-2009, 05:40 PM   #11
creampuff's Avatar
Heaviest? Hmmm, how about this...
Don't mistake a camera's weight with a camera's ability to control mirror shock. The 6x7 is heavy but does suffer from mirror slap.
Same for 35mm film cameras. The newer cameras dampen mirror slap better imo. Perhaps an LX?
06-13-2009, 06:56 PM   #12
ChrisPlatt's Avatar
Not sure if it's the size or weight, but like Paul I find the full-size Pentax bodies easier to hold steady.
Chris
06-13-2009, 07:15 PM   #13
eSFotos's Avatar
QuoteOriginally posted by creampuff Quote
I concur. But given the same mirror shock the heavier camera will damp the shock better. I guess what I really want is a 35mm pentax film camera that has best mirror slap dampen system.
06-14-2009, 05:55 AM   #14
Banned
LX. then get yourself a winder and optional grip. that should give you the weight, and the best pentax 35mm.
06-14-2009, 11:02 AM   #15
Steve Beswick's Avatar
Or you could just get a model that supports MLU.
camera, pentax
For Sale - Sold: Pentax F 70-210mm 4-5.6 and Pentax F 35-70mm 3.5-4.5 Macro and SF1 camera Body jjdgti Sold Items 5 12-30-2009 12:25 PM
For Sale - Sold: Classic Excellent + Chrome ME Camera Body + Original Pentax Leatherette Camera yyyzzz Sold Items 8 11-08-2009 07:53 PM
Hi - from camera newby, Beta - Pentax Optio W60 waterproof camera review beta Welcomes and Introductions 2 03-24-2009 09:44 PM
New camera: Pentax K10D, Nikon D80, Canon 450D, Pentax K200D ??? go4java Photographic Technique 3 03-30-2008 05:36 PM
All times are GMT -7. The time now is 11:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
