04-13-2015, 12:04 PM   #16
Not a Number's Avatar
Update: Ok it looks like the spring is broken as well as the pivot. It seems incredible since spring steel is as tough as... well.. spring steel.
As you can see from the attached photo the arm is missing the extended piece. It looks like it snapped at the "elbow". I'm trying to build up the ridge of the stop even more and perhaps this will work. If it doesn't I either have to get the spring from Ricoh (lots of luck with their parts policy) or buy a donor camera - not worth it really. I can use a rubber band looped over the eyepiece to hold the flash up.
Edit: well the body is a write-off - mirror problem - the pinion gear on the mirror motor must be cracked. Not worth getting the parts and stripping the camera down to get at the gear. Now if there were some other use for the CR-2 batteries...
PENTAX K10D  Photo
04-02-2016, 01:53 AM   #17
calsan's Avatar
UScamera has the pivot in stock. With shipping in the US it will cost you about $12.
Following the above link, I ordered a pivot, plus one spare and a new battery door cover.
After they arrived, I was able to service the pop up flash on my MZ-5.
Below a few photos to help out those who are also planning to do this repair.
Main thing is to note the orientation and placement of the spring that fits over the pivot, which you can see in the last photo.
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
flash, repair
In what situation can you use the external flash that the built in flash couldnt? rustynail925 Flashes, Lighting, and Studio 25 01-13-2010 01:26 PM
flash guide updated for k-7 built-in flash mattdm Pentax News and Rumors 4 05-26-2009 06:02 PM
best way to use built in flash? furby Pentax DSLR Discussion 8 10-01-2008 01:32 PM
wireless flash using built in flash k200d dtra Flashes, Lighting, and Studio 3 04-04-2008 12:34 AM
Using built in flash dvdman45 Pentax DSLR Discussion 9 11-29-2007 05:32 PM
All times are GMT -7. The time now is 02:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
