07-08-2009, 08:58 PM   #1
ismaelg's Avatar
How does the "Program" mode works?
Hi,
I'm looking at an old Super Program body. l understand Aperture priority and shutter priority. But how does the early "Program" setting works? It chooses both parameters, but there is not a single combination that works. Does it favors higher shutter speeds? or certain apertures? Just curious...
Thanks,
07-08-2009, 10:34 PM   #2
Damn Brit
Guest
Moved to film forum Ismael, you should get a faster response there.
07-08-2009, 10:57 PM   #3
KungPOW's Avatar
Are you using a Pentax A lens?
You need to put the aperture ring into the "A" setting, then the camera into Program.
Here is a link to the manual: Pentax Super Program, pentax super A,* instruction manual, user manual
07-09-2009, 04:21 AM   #4
ismaelg's Avatar
Thanks Gary.
Thanks Kungpow, I know how to use it.
My question is more about how does the camera determines the settings, given that there is a range of possible exposures. For instance: 1/60-f11, 1/125-f8 and 1/250-f5.6 are roughly the same exposure.
In other words, how does the algorithm works?
Does it starts at a midpoint aperture and selects the corresponding speed and adjusts from there if too slow? Does it starts with a particular speed? etc.
Thanks,
07-09-2009, 05:55 AM   #5
iirc, there are graphs in the manual that show what the program will be at each EV
page 12 on guide number two on the above link
hate to say it, but this is a case of RTFM
07-09-2009, 06:43 AM   #6
ismaelg's Avatar
I DID RTFM.
Just the first part Sorry....
priority, shutter
Program line: "MTF"? WMBP Photographic Technique 37 11-04-2015 03:58 PM
K20d-Frame Count on panals..works w/"M" & "P" mode only? arbib Pentax DSLR Discussion 1 08-28-2009 05:47 PM
I saw "Fire(works) & I saw Rain" James Taylor Tanglewood (10 pictures) vievetrick Post Your Photos! 8 07-06-2008 09:49 PM
"USER" program mode on the K20D yetidesign Pentax DSLR Discussion 17 06-19-2008 10:23 AM
Flash firing immediately on "2s delay" drive mode oguzgel Pentax DSLR Discussion 5 03-30-2008 01:20 PM
All times are GMT -7. The time now is 03:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
