07-31-2009, 05:56 AM   #1
ismaelg's Avatar
Test results: Pentax SV / SuperTak 55 1.8
Hello,
Continuing with my "Advancing in photography by going backwards", after testing the Spotmatic, I tested my just received Pentax SV with the SuperTakumar 55 f1.8.
Here is a link to my initial post. (https://www.pentaxforums.com/forums/pentax-film-slr-discussion/65092-look-wha...intage-sv.html )
First of all, this camera feels WONDERFUL. I compare it to fine jewelry. The balance, the weight, the look, the smooth controls, everything feels right. No meter, so no batteries to worry about. Handling this is like learning to drive all over again. You realize all you need is to remember the sunny 16 rule and off you go.
However, there seems to be a problem with the lens focusing at infinity. I need to do more testing on this, but these are the initial results.
Again, Kodak Gold 100, quick lo res scans straight from the Noritsu but in this case I did not do any PP.
The following 5 pictures were taken at 1/125 f16
So far so good but here is where the problem shows:
The following 3 scenes were repeated in this order: (1/125 f16) (1/250 f11) (1/500 f8) (1/1000 f5.6)
1/125 f16
1/250 f11
1/500 f8
1/125 f16
1/250 f11
1/500 f8
1/1000 f5.6
1/125 f16
1/250 f11
1/500 f8
1/1000 f5.6
While color saturation improves at wider apertures, focus is definitely off. Shutter speeds seem to be ok. As soon as I get a chance I'll do more testing, including swaping lenses between the Spotmatic and the SV to see how they do. I'm inclined to think the problem is in the SuperTak.
I want to get an adapter to test in the DSLR as well.
Anyways, I'm having a lot of fun with these.
Thanks,
07-31-2009, 07:31 AM   #2
raymeedc's Avatar
Great camera..... Great Lens. I have both (actually, I have five 55s, three Supers & two SMCs). It was my first camera/lens combination when I first started shooting four decades ago. It's still the lens I shoot with most often on my DSLR. Pentax got it right from the get go.
P.S. - Yes, it seems to be that your lens needs adjustment.
07-31-2009, 05:19 PM   #3
geauxpez's Avatar
Wow -- that first shot is expecially impressive.
f11, f16, f5.6, f8, pentax, results, spotmatic, supertak, sv, test
Wireless P-TTL test results adamfogerty Pentax Camera and Field Accessories 3 06-20-2010 05:18 PM
Test results: resurrected Zykkor 135mm Manual Lens ismaelg Pentax SLR Lens Discussion 4 09-27-2009 07:36 PM
Test Results: Helios 44-2/Spotmatic combo ismaelg Pentax Film SLR Discussion 2 08-02-2009 07:41 PM
Pentax 50mm F2 Test results eccs19 Pentax SLR Lens Discussion 6 08-29-2008 12:42 PM
Need help evaluating results from focus test pdmlmember Pentax DSLR Discussion 19 09-11-2007 02:09 AM
All times are GMT -7. The time now is 03:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
