07-31-2009, 08:57 AM   #1
Spotty meter intermittent
A bit stumped on this one... my Spotty developed a weird thing lately, where the meter just stops working for a while, then works fine again. I replaced the original battery cover which was corroded to hell and made sure the contacts are clean and good.
Any suggestions on where to start looking? Not too sure what the most common points of failure are.
07-31-2009, 09:21 AM   #2
In a loud chorus, the standard answer is:
Send It To Eric!
(Sounds like the corrosion extended to the wires/soldering that attach to the battery chamber.)
07-31-2009, 09:23 AM   #3
Nesster's Avatar
Either that or the meter switch has a dirty contact. Try moving it up and down several times to see if that helps
07-31-2009, 09:28 AM   #4
QuoteOriginally posted by Nesster Quote
Yes...I forgot about that switch!
07-31-2009, 09:30 AM   #5
OK, I'll take a look at the switch.
The battery chamber corrosion was almost exclusively on the battery cover itself, so doubt it messed up anything else.
Just wanted to check if there were any known weak points before I tear it apart. Too cheap to pay somebody else unless it's one of the Leicas...
07-31-2009, 01:35 PM   #6
raymeedc's Avatar
I agree, it sounds like the meter switch, a known Spotmatic Achilles heel.
07-31-2009, 03:25 PM   #7
I'll report back once I dig into it. It's my only M42 film camera right now so need it back in working order!
meter
Intermittent blurred pictures with K20D fozzy Pentax DSLR Discussion 13 09-19-2010 05:05 AM
645 intermittent problem :( Asahiflex Pentax Medium Format 6 09-22-2009 09:11 AM
Intermittent AF lamp on Metz 54 MZ-4 glanglois Flashes, Lighting, and Studio 6 05-08-2009 02:25 PM
Intermittent problem w/AF on K10D dales Pentax DSLR Discussion 2 10-28-2008 01:35 PM
K20D softness, intermittent davemdsn Pentax DSLR Discussion 3 06-08-2008 05:01 PM
All times are GMT -7. The time now is 03:45 AM. | See also: NikonForums.com, part of our network of photo forums!
