08-10-2009, 08:06 AM   #1
LX - Q from new owner
I bought an LX today at a camera shop. They told me it was in fine working order - but how do I check it? Also the cover for the external motor is missing. is this a problem? Any idea where to get a replacement? Thanks
08-10-2009, 08:36 AM   #2
Wheatfield's Avatar
QuoteOriginally posted by thomascdk Quote
If it is missing a motor drive cover(s) (there are two) it is not in working condition. The covers are not optional as they light seal the camera.
As far as checking it goes, leave the camera sit for a day and then trip the shutter. If it hesitates, then it has sticky mirror.
You can also check to see if the mirror is in the correct rest position by checking to see if something parallel to the camera (a brick wall for example) can be brought into focus at both the top and bottom of the viewfinder and that this corresponds to a properly focused image.
I test this by focusing the camera and then checking with a groundglass and loupe placed at the focal plane, but checking sharpness of a negative or slide is likely easier for most people.
After that, all you can do is shoot film and see if it is metering correctly. Note that you cannot test the auto exposure on the LX without film in the camera as it is taking it's exposure reading off the film and so needs film for reflectivity.
08-10-2009, 04:11 PM   #3
Another easy way to tell if the mirror rest foam has decayed is to take the lens off and flip the mirror up (mirror lockup, or set to B and hold the shutter button). On each side of the mirror box, near where the bottom of the mirror would be when it is down, there is a little round cylinder of black foam sticking out from the walls. If the cylinder has an indentation in it (and it may be shiny) then the foam throughout the camera is turning into goo and needs to be replaced.
I had mine replaced and overhauled by Pentax Service in Colorado about a year ago; it cost about $300.
08-10-2009, 05:40 PM   #4
Yes, you'll either need to find the covers somewhere or get a Winder LX (or motordrive, but those are tougher to find) and mount it in order to make sure you have a light-tight body.
08-11-2009, 04:07 AM   #5
Thanks for the replies. It goes back to the shop, I think.
08-11-2009, 06:40 AM   #6
Moderator PEG Judges
Kerrowdown's Avatar
That would be a shame, cos it's a great camera with all its bits, you didn't say what you paid for it; to work out if it's worth having serviced and bits replaced.
08-12-2009, 03:05 AM   #7
Well - it went back to the shop. They were embarrassed having sold a camera with these faults. They'll try to have it fixed, but in the mean time I got a M100 macro instead.
So off hunting for that elusive LX again...
lx
New K7 owner LetItRain Welcomes and Introductions 4 07-08-2010 05:12 PM
New owner of k-x sub5runner Troubleshooting and Beginner Help 5 05-31-2010 08:38 AM
New K-x Owner kcrady Welcomes and Introductions 7 04-20-2010 08:21 PM
New K-x owner gramps50 Welcomes and Introductions 6 04-08-2010 09:35 AM
Another new K-x owner... daniel_1234 Welcomes and Introductions 4 12-28-2009 05:18 PM
All times are GMT -7. The time now is 11:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
