Originally posted by lorne-ranger HI,Frank,just posted about same problem and referred here.I have same issue,mirror up,shutter closed.Tried the bash didnt work,did you get yours working.
Thank you Steve
Nah, I gave up already. The camera has been taken apart already. But the problem w/ mine was different: the shutter was hidden blow in the base, just disappeared. 'Cause I pushed too hard when I tried to push it down
Hope you won't make the same mistake when you try the following tricks:
1. Make sure you have fresh batteries installed correctly
2. Set the mode dial to 1/125x or B (not really a must, but better so in my experience)
3. Open up the back door, put your finger tip lightly on the shutter (those hinges visible from the back) and push it gently down. Normally this would fix the problem
4. If not, then you try Wheatfield's trick again, and hit it HARDER
Good luck.
