08-25-2009, 06:38 PM   #1
Should I buy a ZX-7??
Locally I found a ZX-7 for $25, I think I am going to pick it up tomorrow.(this is a good deal right?) But I had a few questions before I got into Pentax's 35mm cameras. I have a k10d, k110d and several lenses and I know they will fit because they are k mount but will the auto focus still work? Also will if I do use those lenses will have to crop the edges because of a difference in sensors sizes from digital to film? Thanks for the help
08-25-2009, 06:58 PM   #2
i say grab the camera and try out some film
out of the lenses you have
70-200 2.8 won't AF
17-50 2.8 will vignette
FA50 will work fine
kit lens will vignette
08-25-2009, 11:46 PM   #3
titrisol's Avatar
Location: In the most populated state... state of denial
For 25 is a good deal, the ZX7 is worth more than that.
The "figital" lenses work well in the ZX7; AF, Aperture, etc.
Some vignetting is visible in the lower end (17-28 mm) but if you use panorama mode most of the vignetting is gone
Be aware that the AF system has improved greatly in the new cameras!
And one advantage of the ZX7 is that it can use OLD lenses in Av mode, which the digitals can not.
08-26-2009, 02:19 AM   #4
Sluggo's Avatar
Make sure of the condition. Many ZX/MZ cameras are up for sale because they don't work. Ask the seller, "does the shutter stick sometimes?" If the answer is yes, then the mirror motor gear is probably cracked, and your $25 is suddenly a bad deal.
lenses
Pentax SMC FA 50mm/F1,4 to buy or not to buy? Eugene-S Pentax SLR Lens Discussion 22 12-05-2010 02:04 PM
Should I buy this laptop to speed up my workflow or buy a new lens? crossover37 Pentax SLR Lens Discussion 26 09-24-2010 09:41 AM
Should I be a good Pentax choirboy and buy a DA 15 Limited or buy the Sigma 10-20mm? tokyoso Pentax SLR Lens Discussion 42 03-14-2010 04:54 PM
SIGMA 70-200mm f/2.8 II EX DG APO Macro HSM Lens for PENTAX:To buy or not to buy? thelittlecar Pentax SLR Lens Discussion 21 12-31-2009 06:01 AM
LBA help! buy 17-70 or sell the 70-300 and buy 18-250 cardikat Pentax SLR Lens Discussion 11 12-30-2009 03:55 AM
All times are GMT -7. The time now is 09:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
