Oren,
As hinted above (I don't know that anyone came right out and said it), a film camera operates the same as your dSLR. Things like auto-focus, programmed exposure, and virtually limitless shots per session make things easier, but the fundamentals remain the same:
- Composition
- Focus
- Exposure
A manual focus camera lacking program exposure automation will help you to consider all three factors for EVERY shot and has the potential to improve your technique. You can accomplish the same thing with your dSLR by turning off AF, setting the camera to constant ISO, and working in Av or M mode. This can be a bit of a pain, depending on what lens you are using, since stop-down metering is a little flaky on current Pentax dSLRs with non-A contact lenses and many AF lenses are poorly suited to manual focus due to short focus throw.
Which brings us back to film...
Advantages:- Use of manual or Av bodies encourages a better understanding of the photographic process
- Manual film bodies are readily available and (for the most part) moderately priced
- The better manual film bodies are optimized for manual technique (e.g. large, bright viewfinders with focusing aids)
- Different films have different characteristics
- With proper technique and media, film can exceed digital in some respects
- Film characteristics can be modified during processing
- Limited number of shots per roll and manual nature of the equipment forces attention to technique
- Satisfaction of taking the "craft" approach to making an image
- Final images can be made using traditional silver-based wet technique or combined into a digital work flow
Disadvantages:- Expense...a minimum of 20 cents per shot for color negative, more for slides, less for B&W negatives
- Limited number of exposures per roll
- Steep learning curve with potential for very poor return on investment (i.e. a full roll shot...no keepers...grrrrr...)
- Local sourcing of film is becoming more difficult
- Quality conversion to digital can be an expensive proposition
Other stuff:- A film kit can be quite a bit more compact than a comparable digital outfit (smaller/lighter body, smaller/lighter lenses, less beefy tripods, etc.)
- Pleasure of using precision-made tools
- Pleasure of having great wide-angle options for landscape work
I shot film for many years before buying my first digicam and am glad for the experience. As a result, I figure that I have a better understanding of the optical system and what to expect from a camera than I might have otherwise. Experience working with a wet darkroom and hours pouring over books by Adams, Bullock and others added an appreciation for response curves, contrast, and limitations of media (photo paper, photo printer, crt, lcd, or projection) available for final viewing.
So, regarding the suggestion about a photo course...I am frequently approached by people wanting to know what dSLR to buy their children for graduation, birthdays, etc.. I always ask them whether the kid is proficient with a film camera. If not, I always suggest that a one-term course at their high school or local junior college before investing a thousand dollars or so on digital body and kit lenses. Those courses are inexpensive and require use of a full manual camera and include basic darkroom technique. At the end of the course, the student will know, at the very least, their orientation to manual technique!
Whew! Sorry for the long message, but those are my thoughts!
(Actually considering buying a 100' roll of off-brand B&W and dusting off the enlarger again...nice enlarger...too bad it has not been used for over 10 years...)
