09-23-2009, 01:01 PM   #1
Film advance jammed on KM
The film advance on my Pentax KM is jammed. here is a photo: http://picasaweb.google.com/aeinstein108/Olympus3?authkey=Gv1sRgCOrcsuP4rr-tFw#
09-23-2009, 01:07 PM   #2
Nesster's Avatar
I can't see the photo (at work) but a bit more description would help - is the mirror up or down, is the shutter armed or not, or partly open... do you have film in the camera and are you past the last frame so the film's stopping you from advancing ( yup)....
09-23-2009, 01:17 PM   #3
I just edited my photo link so it should work now. The film is out of the camera. It locked after I shot about 15 frames of a 36 frame roll. I was able to rewind the film and take it out. The Mirror is in the up position. I can push the shutter release and it seems to move but appears to be stuck about half way. It moves up and down freely but it doesn't really seem to be all the way up. The film advance lever moves out about half an inch and then stops. Thanks
09-23-2009, 01:33 PM   #4
ryan s's Avatar
Couple quick options...
Smack it into the palm of your other hand (seriously!)
Push on the aperture lever inside the mount
Edit: Let me check out the pic closer
Edit edit: Is there a mechanism that slides to the left of that pic (where the big arm goes to)? That might be sticking, preventing the mechanism from moving out of the way.
I'm assuming there is a little "travel" in the advance lever but it doesn't "click" anymore?
09-23-2009, 01:58 PM   #5
Here is a wider shot of the whole mechanism. Picasa Web Albums - Allen - oly4
Yes it doesn't click anymore and there is just a little movement for the film advance lever.
09-23-2009, 02:05 PM   #6
Two more shots from a different angle. It appears that the arm is tuck under the gear. Picasa Web Albums - Allen - Oly5
09-23-2009, 02:11 PM   #7
I had read about the smacking thing before and damn near bruised my hand smacking the you know what out of it. No luck there.
09-23-2009, 02:22 PM   #8
ryan s's Avatar
Here's what I would try in order:
Push the long silver lever all the way through its stroke
If that doesn't work, try to get the largest black sprocket to move
If those don't work, then I'm not sure. Those steps have always worked in the past.
09-23-2009, 02:32 PM   #9
Thanks for the info. but nothing helped. It appears to be totally jammed up and nothing moves. The, what I think is the aperature lever, moves but nothing else.
09-23-2009, 02:57 PM   #10
monochrome's Avatar
If all else fails, send the camera to Eric Hendrickson for a quote - best Pentax Camera tech on Earth - literally - and used by many, many members here to bring their classic cameras and lenses back to life.
www.pentaxs.com Reviewed in the Camera Service and Repair section of the External Links Forum. Usually less than $65 for this repair, plus a complete CLA to factory specs.
09-23-2009, 03:11 PM   #11
ryan s's Avatar
The aperture lever is on the left as you look "into" the camera.
Well to be honest, I'd just start poking around carefully with a small screwdriver
OH...one thing I forgot...slide the lever that's directly under the lens mount. It's the one connected by the thin wire and goes "front to rear" in relation to the camera.
If nothing "pops" back into place with some fiddling...the wind mechanism might have been sheared off under the top plate
09-23-2009, 04:20 PM   #12
The lever you mention is stuck up against the arm shon in the picture. Let me tell you this. The take up spool moves freely with my fingers pushing it and it turns easily. Is that normal?
09-23-2009, 04:28 PM   #13
Also if the wind mechanism is sheared off under the top plate is this camera a goner?
09-23-2009, 04:31 PM   #14
Thanks for the tip on a good repair shop.
09-23-2009, 04:36 PM   #15
ryan s's Avatar
QuoteOriginally posted by Kmman Quote
That big, black gear rotates, pushing the longest lever...the lever that's underneath the lens mount should move with it. Start pushing and poking around since that should free something up...
When the shutter is cocked, the ME Super's and Spotmatic's take up and alignment spools both rotate, although not easily. When the shutter is not cocked, neither reel should move.
I'm not a pro, so I don't know how freely they should move. All I know is that they do move when the shutter is cocked.
Not necessarily, but it will have to be sent to Eric if it needs replacement.
I'm pretty convinced there's something stuck and not finishing its "cycle" in the winding/firing down below that bottom plate...
advance, film, film advance, km
645n film advance noise khaki8 Pentax Medium Format 2 09-28-2010 01:34 PM
ZX-7 Film Advance Troubles shiestmiester Film SLRs and Compact Film Cameras 4 06-01-2010 06:10 AM
ZX-L film advance problem clawhammer Film SLRs and Compact Film Cameras 5 08-16-2008 08:54 PM
35mm Film Advance error DigiNoob Film SLRs and Compact Film Cameras 2 09-18-2007 02:51 PM
Pentax MG film advance Vellian Film SLRs and Compact Film Cameras 1 02-05-2007 07:13 AM
All times are GMT -7. The time now is 05:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
