11-01-2009, 10:56 PM   #1
Repair Asahi SPII My Light Meter
Hello dear forumers,
Hope to seek some advice from you guys,
I've bought this Asahi SP2 from Ebay recently and found out the light meter "joint" (not sure what is it called) was snapped into 2 (please refer the picture attached).
Everything works in good shape except the light meter was a bummer =/
is there any other alternatives to get this fix or replace the "metal" piece?
highly appreciated of anyone have a solution to this....
11-01-2009, 11:48 PM   #2
rormeister's Avatar
Contact Eric Hendrickson @ Home. He's amazing.
11-01-2009, 11:52 PM   #3
I think you can just solder the two pieces back together.
If you don't have a solder iron, have a beer from an aluminum can and cut a replacement from the (now empty) aluminum can . The replacement doesn't need to be exact, as long as it can conduct electricity from the battery compartment.
You can also give conductive glue a try. You can get it from auto part store. It's the same glue used to fix heater element in car's rear window. If you don't know what it is, do a search for "conductive glue" or "wire glue."
11-02-2009, 12:14 AM   #4
i will give the aluminium can a try tonght will let you guys know if it works or not..
Thanks for the tips!
Tried with the aluminum can piece and got reaction, but the needle is always in "under expose" or "over expose" position when i fiddle around the ASA speed.
I've used the same battery that works on my SP 1000.
Guess i'll just send the camera for repair.... =/
what a bummer..
asahi, light, meter
Asahi Pentax Meter on S1a tommessenger Pentax Film SLR Discussion 10 04-27-2011 07:18 AM
Light Meter won't work on my Asahi Pentax KX AnthonyG Troubleshooting and Beginner Help 3 12-04-2009 03:14 PM
Asahi SPII My Light Meter Isn't Working. Cameron030293 Pentax Film SLR Discussion 7 10-13-2009 06:46 AM
Asahi ME worth repair? roberta Pentax Film SLR Discussion 3 11-25-2008 04:43 PM
Asahi Pentax ME, Light Meter not Working MacetheAce Photographic Technique 12 10-04-2008 02:31 PM
All times are GMT -7. The time now is 04:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
