11-05-2009, 12:07 PM   #1
MX bottom plate compatibility
Sorry if this question has been asked -- I've been searching the forum, but haven't seen it yet. Feel free to point me to it if already discussed.
Do any other bodies share the same bottom plate as the MX? I have a very nice functional MX, with the common issue of a dented bottom plate and would like to replace it. MX parts have been scarce, but maybe another body used the same plate? I don't have other bodies to compare.
Also, if anyone has an MX parts body I'd be open to talking.
Rick
11-05-2009, 12:31 PM   #2
What about removing the plate and knocking the dent out? If you get a flat workbench and a bit of wood then tap gently with a hammer you should be able to straighten it in the same way as a dented car body.
I've done this with a battered MV1 with reasonable success - it isn't perfect but it's better than it was.
11-05-2009, 03:40 PM   #3
Ratmagiclady's Avatar
I'm sure someone here would know definitively, but I think the MX may have been the only one made like that before they went to the ME type bodies. (I was pretty sure I heard that only the MX can use the winder for that, which would mean the bottom plates are specific to those. )
11-05-2009, 03:53 PM   #4
QuoteOriginally posted by Ratmagiclady Quote
...the MX may have been the only one made like that before they went to the ME type bodies. (I was pretty sure I heard that only the MX can use the winder for that, which would mean the bottom plates are specific to those. )
Yup. That's correct. MX doesn't share parts with any other Pentax camera.
11-05-2009, 04:28 PM   #5
Thanks to each of you -- this is very helpful.
Rick
bodies, body, bottom, mx, plate
help with bottom line on K-5, please WMBP Pentax News and Rumors 58 09-08-2010 08:42 PM
Black & White Bare Bottom tuco Post Your Photos! 2 05-12-2010 03:18 PM
Does the cracked bottom plate affect weather sealing? jct us101 Pentax DSLR Discussion 20 08-28-2009 09:52 AM
Cracked bottom plate on K20D slawek Pentax DSLR Discussion 6 07-27-2009 07:58 PM
Crack on bottom sabarrett Pentax DSLR Discussion 1 01-22-2008 10:29 AM
All times are GMT -7. The time now is 12:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
