Originally posted by ChrisPlatt Scanner settings/tips?
Chris
Epson V500 using Epson software in Professional mode.
I did a prescan with the Autoexposure set at the middle and then using the color/lighting curve tool, starting with a linear line I pulled the red and blue down a bit at the middle and then push lighting up a bit in the middle. I saved that and applied it to all subsequent shots. This was a good starting point for most of the shots. I did some very slight adjustments from there for a few shots depending on the exposure or if I wanted more contrast.
