View Poll Results: Which one will you buy if you already have a KM..the KX or the K2?
K2 1335.14%
KX 1643.24%
Neither, just stick with the KM 821.62%
Voters: 37. You may not vote on this poll
11-21-2009, 01:08 PM   #16
monochrome's Avatar
Still won't give it up
QuoteOriginally posted by Ole Quote
If you're left-eyed, it is an easy choice: The K2.
The KX is the only Pentax which will only meter when the rapid wind lever is poking into your right eye! In other words, with the rapid wind lever flush with the body: No metering.
I had to switch eyes a couple years ago due to vision decline. Even so, I won't let go of my KX (although the K2DMD sees a lot more use now).
11-21-2009, 01:53 PM   #17
Blue's Avatar
QuoteOriginally posted by altair Quote
Everyone, thanks for all your very helpful replies. I'm still digesting them, hope I can come to a decision soon!
By the way, the seller sent me some photos of the K2 just now. Everything looks ok, except for a dark smudge on one of the shutter blades. I asked him about it and he said it's not oil, just a dark smudge. He tried cleaning it with naphta & Qtips but it's still there. Perhaps it's just discoloration due to rubbing of the shutter blades? Is this a potential problem?
If it is just a stain, I don't think it would cause any problems. Did you ask about the film speed ring?
11-24-2009, 04:24 PM   #18
8540tomg's Avatar
For my money it's the K2 all the way.
You have the option to shoot in manual if you wish and auto if your don't. An awesome array of features: DOF preview, mirror lockup, ASA range fro 8~6400, etc and that great sounding shutter. Even works without batteries. ASA ring issues are blown way out of proportion. Use the K2 for a while and you will get rapidly use to it just as you would the idiosyncrasies of any other camera.
Tom G
11-24-2009, 10:29 PM   #19
Thanks for all your invaluable input everyone. I went for the chrome-bodied K2, got it for $42! But shipping is another $40, so that's $80 in total. Hmmph! Hope everything will be fine with it.
In the end, what made me decide on the K2 is that I'm left eyed, so I really don't want the advance lever to be poking in my eye when I want to meter. I have another SLR that does that, the Konica Autoreflex TC, and that lever poking in your right eye is a hindrance & detracts from the experience. Thanks to the person who mentioned this.
Anyway, now to get some more lenses. I only have 2 normal lenses now in K-mount, the SMC Pentax A 50/2 and the SMC Pentax M 50/1.7. Good lenses, but I'm not too keen on their plastic construction..a far cry from the metal of the screwmount lenses! Are there any metal-bodied/barreled K mount lenses out there? Which one is good? I want a wide angle & a tele.
11-24-2009, 10:50 PM   #20
gofour3's Avatar
Check out the "K" series lenses, they are all metal and from the same period as your camera.
Also look at the forum lens review section for more info.
Phil.
11-25-2009, 01:16 AM   #21
Jimfear's Avatar
How much wideangle and how much tele? There is a bunch of K series lenses so you would really need to specify a little more to get good recommendations. "a wide angle & a tele" encompasses from 15mm to 300mm with the exception of 40-50mm lenses.
11-26-2009, 02:08 AM   #22
artobest's Avatar
Apart from the little focusing ring cover, the M 50/1.7 is all metal. A sturdy little lens, treasure it, don't underestimate it!
11-26-2009, 07:29 AM   #23
titrisol's Avatar
Location: In the most populated state... state of denial
Plastic?
those lenses are metal. Yes they have a small rubber ring to give you better hold but thay ain't no plastic
The 50/1.7M is a great lens, and the 50/2 is a good one (the difference between A and M IIRC is the electronic contacts only)
wide angle? how wide? a 28/2.8 used to be the standard and those should not be too expensive
Tele - how big? I'd like a 200 but have the 135M is a good compromise
aperture, asahi, camera this month, electronics, k2, km, kx, month kx, pentax, shutter
Camera survives 6 month ocean trip to Fla. xs400 General Talk 6 06-16-2010 05:39 PM
HOW (where) did you buy your Pentax camera? WMBP Photographic Technique 36 05-28-2009 01:59 PM
What do I need to buy for this combo (TTL) off camera sharpshoota Pentax Camera and Field Accessories 0 06-19-2008 03:48 AM
Help! Which camera to buy?? xxatti Pentax DSLR Discussion 5 04-01-2008 09:31 PM
Best place to buy camera accessories spillway Pentax Camera and Field Accessories 11 03-07-2007 11:16 AM
All times are GMT -7. The time now is 07:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
