11-20-2009, 07:40 AM   #1
K-1000 Hot Shoe Question
Is the flash hot shoe on the K-1000 powered at all by the camera battery?
I have an old Focal DA-200S-CH flash that tests fine, but does not flash when I try it in the shoe with a 400ASA / 60 /f8 setting.
I know the camera battery needs replaced, but am curious to know if it even powers the shoe.
Help & advice? I hadn't touched the camera in over 20 years until this week, so am sort of starting out new.
Thanks
11-20-2009, 08:28 AM   #2
QuoteOriginally posted by robieusa Quote
Thanks
The hotshoe is not usually powered at all. It is merely a switch. When you trip the shutter, the switch closes momentarily, triggering the flash.
You say that the flash tests okay. By that, I assume that you are using the on-flash test button. Try shorting the contacts on the flash's shoe. It may be that the shoe on the flash is bad. If shorting the contacts does not cause the flash to fire, then the flash shoe is bad. If it does fire, your problem is probably in the camera.
I'm not sure how to test the camera hotshoe, other than by using another, known-good flash unit. If the flash has an optional PC cord, you might try using that.
11-20-2009, 10:27 AM   #3
If the camera needs the battery replaced start there.
Since most cameras I know of use their battery up faster while using flash my guess is that it uses some battery power to trigger the flash.
11-20-2009, 10:30 AM   #4
The K1000 does not need a battery to fire the flash. The battery is only used for the meter circuit. I use them without a battery at all for astro work.
11-20-2009, 07:31 PM   #5
QuoteOriginally posted by little laker Quote
You're talking about camera with built-in flash.
As stated, the only thing using battery in the K1000 is the light meter. Other than that, the camera is fully mechanical. It doesn't need battery to function.
11-21-2009, 06:10 PM   #6
Yep, the hot shoe is not really hot at all...
11-24-2009, 10:27 AM   #7
unixrevolution's Avatar
We should call it a "warm-shoe."
And yes, the K1000 should be able to trip the flash without a battery. As a poster said above, short the flash or use it on another camera, and test the camera with known good flash to determine what's wrong.
11-26-2009, 10:32 AM   #8
short the flash ???
OK. So, how do I short the flash? Pretend that you're explaining it to a 3-year-old.
Again,, it's been about 20 years since I have touched a camera. Lots of knowledge has evaporated.
I am planning to take the camera in to the shop next week for a clean-up & check-up... but knowing how to test the flash will be helpful knowledge.
Thanks
11-26-2009, 07:53 PM   #9
Shorting the flash
short the flash ???
Thanks
The contacts on the flash hotshoe consist of two connections. One is the center pin, which is easily visible in the center of the hotshoe. The second is a little bit hidden. In one or both of the two slots on the sides of the flash hotshoe, look closely and you will see a metal piece. This contacts the metal lip on the side of the camera hotshoe and forms the second connection.
Simply take a piece of wire or a straightened out paper clip and short the center pin to the side connector. This is what the camera does, and will make the flash go off, if the hotshoe is working properly.
If the flash does not fire, you may be able to remove the hotshoe and re-solder the wires that connect the internal circuitry of the flash to the hotshoe. I'm not familiar with your particular flash, but most of the flashes from that era are similar.
Its safe and easy. Good luck.
battery, camera, flash, k-1000, k-1000 hot shoe, shoe
Hot shoe question Gerrys Troubleshooting and Beginner Help 9 10-21-2010 05:54 PM
Wanted - Acquired: Wein Hot Shoe to Hot Shoe Safe Sync HSHSB 990-560 excanonfd Sold Items 0 08-26-2010 10:56 AM
Hot shoe question Rondec Pentax DSLR Discussion 9 11-03-2009 10:21 PM
Wein Safe-Sync Hot Shoe to Hot Shoe Iowa Tom Pentax DSLR Discussion 1 09-12-2009 09:20 PM
Noob Question II : PC Cords vs Hot Shoe Adaptors Christopher M.W.T Troubleshooting and Beginner Help 1 07-18-2009 08:47 AM
All times are GMT -7. The time now is 08:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
