Hin,
In regards to my "report", you are welcome
This afternoon I got my second roll of BW400CN developed and scanned, this time I made sure I didn't use the hood at all. As you mentioned, I also get used to using the hood, and try to make sure I am using one on any lens I use.
Anyway, onto the verdict, which is strangley mixed. This is beyond my understanding, but some of the shots show very obvious vignetting, while others show much milder vignetting (such that it can almost be removed by PP), and some show almost none.
For example, here is a shot showing a fair amount of vignetting:
1.
And here is another shot where the vignette seems to be a bit less severe:
2.
Now here is the same shot as #2 with some quick PP work in Lightroom to reduce the vignette, no cropping
3.
Lastly, this shot was taken in the macro range of the DA35, close to 1:1 from memory
4.
In my uneducated understanding, it looks like the focusing distance is having an impact on the vignetting observed. Now unfortunately I didn't record the exact aperture setting of each photo, but it was bright sunlight so most were from F8 to F11.
I would guess that as long as you are prepared to allow a fairly small crop when composing a shot, that the DA35 will work pretty well. Or if it is used for macro duties then maybe it will be fine. A "wide-angle" macro is quite fun too, maybe my next project will involve flower photos with some good colour film... I don't really know what "good colour film" is though!
cheers,
Jason
